Earl 01 Posted December 16, 2020 Share Posted December 16, 2020 Have a good 6 cyl in my 01 Outback (with a rusted out rear cradle). Want to put it in a 00 Outback. Or change complete rear cradle from 00 to 01. Has anyone attempted either of these changeovers? Quote Link to comment Share on other sites More sharing options...
john in KY Posted December 16, 2020 Share Posted December 16, 2020 (edited) I replaced that cradle a few years ago. Removing those bolts that bolt the cradle to the frame required a 4 foot cheater bar. The engine swap will be much easier. Was under the impression the swap was between 2 H6 vehicles. Edited December 16, 2020 by john in KY Quote Link to comment Share on other sites More sharing options...
Earl 01 Posted December 16, 2020 Author Share Posted December 16, 2020 Thanks so much for that info. Now I will have to find out if the 6 cyl will bolt into the 4 cyl car. Thanks again and Merry Christmas, Earl Quote Link to comment Share on other sites More sharing options...
montana tom Posted December 16, 2020 Share Posted December 16, 2020 Hi Earl; The entire wire harness and computer would need to go with the 6cly . I would change the cradle if I were you Quote Link to comment Share on other sites More sharing options...
3Pin Posted December 16, 2020 Share Posted December 16, 2020 I agree with Montana tom . the rear support will be an easier maneuver for sure. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 16, 2020 Share Posted December 16, 2020 Ones that need the rear cradle replaced can have enough rust elsewhere that it’s a huge waste of time. Make sure it’s worth it with that out of the way. Rear support. They’re replaced fairly regularly. swapping a 4 and 6 is a huge undertaking, extracting, labeling trimming the nasty wiring harness because you have to swap the body side wiring and ECU and do some splicing. If the receiving car is an auto you’ll have additional issues. 2 Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 16, 2020 Share Posted December 16, 2020 Yep, the 6-cylinder will mechanically bolt into the 4-cylinder car, they are the same chassis. But ALL the wiring will have to be changed, which means the dash has to come out. Having done dozens of engine swaps, and recently replaced the rear subframe in my 330k mile 2000 OBK, the subframe is 1000x easier. 3 Quote Link to comment Share on other sites More sharing options...
Earl 01 Posted February 7, 2021 Author Share Posted February 7, 2021 Thanks to all of you. I have decided to sell the car for parts and work on an 04 legacy outback 2.5 manual trans with a sticking brake pedal. 1 Quote Link to comment Share on other sites More sharing options...
