Sasse Posted May 3, 2021 Share Posted May 3, 2021 (edited) Hi all, been slowly making progress w/ my Brat. It is now safe and roadworthy. My newest issue is the transmission is leaking badly at the shifter shaft seal. my questions are; can it be replaced without removing the transmission? and any words of wisdom or advice before I dig in? So far I have: replaced a head due to a previously botched helicoil for a sparkplug. Replace h2o pump, hoses, radiator. Installed new 32/36 (it runs, but not quite right, but that is a later project). Redid all brakes that need immediate attention. Fixed the leaking t-top. Replaced a bunch if wheel studs. Entirely replaced exhaust. And, additional sundry repairs and maint. thanks in advance. Edited May 3, 2021 by Sasse Quote Link to comment Share on other sites More sharing options...
Subi81 Posted September 30, 2021 Share Posted September 30, 2021 Yes the shifter seal can be replaced without removing the trans, I was able to do it on my 81 wagon without much trouble. I think the hardest part was getting the cross pin out of the shifter linkage. I am sure there is a write up somewhere around here. Found some advice here: Quote Link to comment Share on other sites More sharing options...
Sasse Posted October 2, 2021 Author Share Posted October 2, 2021 On 9/29/2021 at 9:05 PM, Subi81 said: Yes the shifter seal can be replaced without removing the trans, I was able to do it on my 81 wagon without much trouble. I think the hardest part was getting the cross pin out of the shifter linkage. I am sure there is a write up somewhere around here. Found some advice here: Thanks Quote Link to comment Share on other sites More sharing options...
el_freddo Posted October 3, 2021 Share Posted October 3, 2021 Make sure there are no burrs on the selector shaft. Last thing you want to do is cut up the new seal as you install it! Cheers Bennie Quote Link to comment Share on other sites More sharing options...
