gbacon67 Posted October 18, 2021 Share Posted October 18, 2021 Hello, I'm looking for the thermostat housing / idle air control housing for a 1985 GL-10 with EA82T engine. See photo. It's a discontinued item. Please share any good sources for used Subaru parts Let me know of any workarounds for separating the thermostat housing from the idle air control. Subaru went to a standard thermostat cover and a separate idle air control widget on later models. I'm guessing I could switch to different parts and still get accurate idle air control. Thank you! Quote Link to comment Share on other sites More sharing options...
Step-a-toe Posted October 19, 2021 Share Posted October 19, 2021 I disconnected mine totally, electrically and air wise from intake system. Takes a bit more effort to warm up. Might be hard to get a wrecker interested in parting with such a small value item Quote Link to comment Share on other sites More sharing options...
KiwiGL Posted October 20, 2021 Share Posted October 20, 2021 On 10/19/2021 at 2:56 AM, gbacon67 said: Hello, I'm looking for the thermostat housing / idle air control housing for a 1985 GL-10 with EA82T engine. See photo. It's a discontinued item. Please share any good sources for used Subaru parts Let me know of any workarounds for separating the thermostat housing from the idle air control. Subaru went to a standard thermostat cover and a separate idle air control widget on later models. I'm guessing I could switch to different parts and still get accurate idle air control. Thank you! I've read a couple of threads of people using Bosch ones to fit early VW Golf models instead. These are still available. See this thread https://www.ultimatesubaru.org/forum/topic/141806-aaviacv-questions/ Quote Link to comment Share on other sites More sharing options...
gbacon67 Posted September 7, 2022 Author Share Posted September 7, 2022 Belated thank you for the help. I made a JB Weld repair that seems to be successful. I now have options thanks to your help 🙂 Quote Link to comment Share on other sites More sharing options...
