re-evaluating Posted October 19, 2021 Share Posted October 19, 2021 I am trying to find out what steering columns will fit my 85 Brat (close to plug and play as possible). The dingleberry I got the Brat from destroyed the column because he didn't have the key. I have searched without any luck though maybe I am using the wrong term. Any help would be appreciated. Yes I am looking for a column if you happen to have one that will work. THANKS in advance. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted October 22, 2021 Share Posted October 22, 2021 You can use a coupe, wagon, hatch or sedan EA81 steering columns - but the ignition switch will be setup differently. Any other models will most likely need to have the mounts modified. I’ve seen WRX steering wheel and the matching columns fitted in Brats with a WRX conversion. You can do anything with enough effort and motivation to achieve the desired outcome... Cheers Bennie Quote Link to comment Share on other sites More sharing options...
