nipper Posted November 7, 2021 Share Posted November 7, 2021 2019 Subaru Outback What are we doing for code readers that play nice with Subaru and can change settings without blowing the bank. Quote Link to comment Share on other sites More sharing options...
brus brother Posted November 7, 2021 Share Posted November 7, 2021 what settings are you looking to change? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 7, 2021 Share Posted November 7, 2021 Not sure what you mean but I don’t think there are any “code readers” that “change settings”. (see my assumptions below) If you mean altering tables and settings like I’m thinking thats usually done via Rom Raider and other PC based OBDII cable adapter software. I’m assuming by code reader you mean OBDII scanners that read and log data. And I’m assuming “change settings” means you want to alter the tables in the controllers. 2 Quote Link to comment Share on other sites More sharing options...
nipper Posted November 7, 2021 Author Share Posted November 7, 2021 There are may code readers, but a lot of them dont play well with subaru. Im not looking to hack it, im looking for a really good diagnostic tool for the entre car. Quote Link to comment Share on other sites More sharing options...
Ferret54 Posted November 7, 2021 Share Posted November 7, 2021 From when I worked at a Subaru Service center, options as you have above were only available with the proper module for that specific year/model with the Subaru Select tool. TOO expensive for me as I continue to do work in my garage/driveway. Best tool I have is an Autel MK906 I paid almost a grand for. Works for every car I service so far. I can operate solenoids and check that they DO work, do cam advances and check the sensor reads properly, etc. Reset and IF manufacturer allow you, change oil change frequency to any presets they have programmed. But Vehicle/User Specific options you pasted above, I only saw with the Subaru SST. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 7, 2021 Share Posted November 7, 2021 at www.subaruoutback.org , there is a thread about FreeSSM and similar tools. Maybe someone over there can assist with the question? (SSM=Subaru Service Monitor, the dealer's software) 2 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 8, 2021 Share Posted November 8, 2021 8 hours ago, Ferret54 said: From when I worked at a Subaru Service center, options as you have above were only available with the proper module for that specific year/model with the Subaru Select tool. TOO expensive for me as I continue to do work in my garage/driveway. Best tool I have is an Autel MK906 I paid almost a grand for. Works for every car I service so far. I can operate solenoids and check that they DO work, do cam advances and check the sensor reads properly, etc. Reset and IF manufacturer allow you, change oil change frequency to any presets they have programmed. But Vehicle/User Specific options you pasted above, I only saw with the Subaru SST. That is most excellent to be aware of! Thanks for posting. 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 8, 2021 Share Posted November 8, 2021 9 hours ago, nipper said: There are may code readers, but a lot of them dont play well with subaru. Im not looking to hack it, im looking for a really good diagnostic tool for the entre car. Ah I see what you mean. Those would be nice for the owner to manually toggle. Those aren’t accessible by OBD scanners. I wonder where those tables and features are stored? Are they in a dedicated controller? 1 Quote Link to comment Share on other sites More sharing options...
Ferret54 Posted November 8, 2021 Share Posted November 8, 2021 These options are probably in the BCM ( Body Control Module ). Most over the counter OBDII tools are programmed for the ECU,ECM,PCM Engine modules, Transmission Modules, Airbag Module and ABS module. Other modules on the CAN buss usually require vehicle specific tools. There are so many indivual controller on the CAN buss these days. You can't even change a radio out for one with better sound/options since it also is on the CAN buss and can control other options from there. 1 Quote Link to comment Share on other sites More sharing options...
nipper Posted November 12, 2021 Author Share Posted November 12, 2021 On 11/8/2021 at 7:12 AM, Ferret54 said: These options are probably in the BCM ( Body Control Module ). Most over the counter OBDII tools are programmed for the ECU,ECM,PCM Engine modules, Transmission Modules, Airbag Module and ABS module. Other modules on the CAN buss usually require vehicle specific tools. There are so many indivual controller on the CAN buss these days. You can't even change a radio out for one with better sound/options since it also is on the CAN buss and can control other options from there. I wish the radio had more volume. Quote Link to comment Share on other sites More sharing options...
