Washington Moss Posted January 23, 2022 Share Posted January 23, 2022 Hey all, longtime reader here. I’ve gotta tons of great information from you guys in the past 10 years of owning subarus, so thanks in advance. Ok, hoping I can get some ideas on this problem that’s been driving me crazy. 1999 outback leggy, 2.5 dohc, 5-speed, 215k miles. Had a cyl4 missfire code that went away with new plugs and wires, but it comes and goes still, Although I don’t think that’s related to the issue I’m having. Car started randomly cutting out while highway driving, throttle did nothing for a few seconds like it was cutting spark or fuel completely.. But would come right back online after pumping to the floor a couple times. Cold starting it will start and idle but sometimes dies after 5-10 minutes, then starts right back up and idles. Car runs perfect when that’s not happening. I’ve driven it probably 200+ miles with this problem but it’s been getting more frequent. Sometimes it will completely cut out and not come back, then I turn the key off then it starts right back up and runs but cuts in and out frequently at any speed. yes the battery terminals are clean and have good connections, grounds as well. Things I’ve done/tried: New plugs, new wires, new ignition coil, fuel filter, fuel pump. Tried new cam and crank position sensors, Looks like all the connections are good on the harness. I unplugged the MAF and drove it around and the same symptoms came up. Any ideas on what I should look for/try next? Quote Link to comment Share on other sites More sharing options...
forester2002s Posted January 23, 2022 Share Posted January 23, 2022 15 minutes ago, Washington Moss said: ...then I turn the key off then it starts right back up... Hmm. I wonder... Electrical problem with contacts in ignition-key? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 23, 2022 Share Posted January 23, 2022 TPS signal dropping out? Maybe get an analog meter on the tps output and exercise it to see if resistance change is smooth. Quote Link to comment Share on other sites More sharing options...
Washington Moss Posted January 23, 2022 Author Share Posted January 23, 2022 53 minutes ago, forester2002s said: Hmm. I wonder... Electrical problem with contacts in ignition-key? Sorry that might be confusing. turn the car off, and then crank it over again and it fires right back up. Quote Link to comment Share on other sites More sharing options...
Washington Moss Posted January 23, 2022 Author Share Posted January 23, 2022 14 minutes ago, 1 Lucky Texan said: TPS signal dropping out? Maybe get an analog meter on the tps output and exercise it to see if resistance change is smooth. Good idea! Quote Link to comment Share on other sites More sharing options...
forester2002s Posted January 23, 2022 Share Posted January 23, 2022 2 hours ago, Washington Moss said: Sorry that might be confusing. turn the car off, and then crank it over again and it fires right back up. Yes, but it could be a loose or corroded set of contacts in the ignition-key unit. Maybe you have an intermittent connection, that works sometimes and then cuts out. Next time you have a problem, jiggle the ignition-key and see what happens. 1 Quote Link to comment Share on other sites More sharing options...
Washington Moss Posted January 23, 2022 Author Share Posted January 23, 2022 1 hour ago, forester2002s said: Yes, but it could be a loose or corroded set of contacts in the ignition-key unit. Maybe you have an intermittent connection, that works sometimes and then cuts out. Next time you have a problem, jiggle the ignition-key and see what happens. Hmm maybe, I think I woulda noticed that when I’ve turned the key off then back on. Which I’ve had to do a lot. But it’s worth a try Quote Link to comment Share on other sites More sharing options...
logic23 Posted January 24, 2022 Share Posted January 24, 2022 Check the grounds. The main one from the negative side of the battery to the starter can get funky and cause issues. There is one on the intake that can also get checked. And the one from the battery to the body of the car. I have seen all 3 of those get cruddy and cause all kinds of issues 1 Quote Link to comment Share on other sites More sharing options...
Washington Moss Posted January 25, 2022 Author Share Posted January 25, 2022 On 1/23/2022 at 8:55 PM, logic23 said: Check the grounds. The main one from the negative side of the battery to the starter can get funky and cause issues. There is one on the intake that can also get checked. And the one from the battery to the body of the car. I have seen all 3 of those get cruddy and cause all kinds of issues I’ve cleaned and reconnected all 3 of those ground contacts. None of them were cruddy. Quote Link to comment Share on other sites More sharing options...
Washington Moss Posted January 25, 2022 Author Share Posted January 25, 2022 Anybody got anything else? I’m stumped Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 29, 2022 Share Posted January 29, 2022 Main Power relay up under the dash. Fuel pump relay Any related sounds missing when it dies. Do you loose all power? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 30, 2022 Share Posted January 30, 2022 22 hours ago, lmdew said: Main Power relay up under the dash. Fuel pump relay Any related sounds missing when it dies. Do you loose all power? great idea, had a similar issue with a 90 Maxima my daughter drove. Sometimes, you can experiment by swapping with another relay - what? headlight or ac comp? - often 2-3 relays are the same part# employed for different functions. Quote Link to comment Share on other sites More sharing options...
Washington Moss Posted January 30, 2022 Author Share Posted January 30, 2022 On 1/29/2022 at 12:06 PM, lmdew said: Main Power relay up under the dash. Fuel pump relay Any related sounds missing when it dies. Do you loose all power? Still gotta try those. I don’t lose all power, just fuel or spark it seems Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 31, 2022 Share Posted January 31, 2022 inspect throttle body, maybe it needs cleaning? Quote Link to comment Share on other sites More sharing options...
