Issac Posted May 2, 2022 Share Posted May 2, 2022 Anyone know were to find a fuel level sender unit I can't find one anywhere Quote Link to comment Share on other sites More sharing options...
pksjeep Posted May 2, 2022 Share Posted May 2, 2022 I don't know for sure on this car, but most sending units are in the gas tank. Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted May 2, 2022 Share Posted May 2, 2022 14 hours ago, pksjeep said: I don't know for sure on this car, but most sending units are in the gas tank. Pretty sure they need a new/used replacement, not locating it on the car. 16 hours ago, Issac said: Anyone know were to find a fuel level sender unit I can't find one anywhere Are you sure the sender is bad, and not just the wires? Mine had a wire go bad where it goes though the tank. I stripped it all down, used some new fuel safe wires and epoxy to reseal it. 1 Quote Link to comment Share on other sites More sharing options...
Issac Posted May 2, 2022 Author Share Posted May 2, 2022 19 hours ago, pksjeep said: I don't know for sure on this car, but most sending units are in the gas tank. I meant to find a new one I didn't make that very clear lol 1 Quote Link to comment Share on other sites More sharing options...
Issac Posted May 2, 2022 Author Share Posted May 2, 2022 4 hours ago, Ionstorm66 said: Pretty sure they need a new/used replacement, not locating it on the car. Are you sure the sender is bad, and not just the wires? Mine had a wire go bad where it goes though the tank. I stripped it all down, used some new fuel safe wires and epoxy to reseal it. No I pulled it out and inspected it it's coveted in rust and is froze up completely Quote Link to comment Share on other sites More sharing options...
el_freddo Posted May 3, 2022 Share Posted May 3, 2022 17 hours ago, Issac said: No I pulled it out and inspected it it's coveted in rust and is froze up completely Have you tried to free up the moving parts then clean up the contact tracks? If you manage to do this it’s an easy check to see if it will work before reinstalling Cheers Bennie Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 3, 2022 Share Posted May 3, 2022 paging @lmdew got parts? Quote Link to comment Share on other sites More sharing options...
1980ea71Brat Posted May 5, 2022 Share Posted May 5, 2022 I have done some research on this and it seems the part number 85111GA153 has been discontinued across the board for basically all 1994 leones and older with the analog gauges. My question (not to steal this thread) is can we adapt a universal fuel sending unit to our tanks? Has anyone used a different make and model part as a replacement? Quote Link to comment Share on other sites More sharing options...
Issac Posted May 6, 2022 Author Share Posted May 6, 2022 On 5/3/2022 at 10:40 AM, el_freddo said: Have you tried to free up the moving parts then clean up the contact tracks? If you manage to do this it’s an easy check to see if it will work before reinstalling Cheers Bennie Yes i have cleaned everything and even fixed the wires that are broke still just trips out and moves all over the place 1 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted May 7, 2022 Share Posted May 7, 2022 That’s a bugger mate. Hopefully you can find a usable replacement unit. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
newmexguy Posted May 15, 2022 Share Posted May 15, 2022 On 5/5/2022 at 12:00 PM, 1980ea71Brat said: I have done some research on this and it seems the part number 85111GA153 has been discontinued across the board for basically all 1994 leones and older with the analog gauges. My question (not to steal this thread) is can we adapt a universal fuel sending unit to our tanks? Has anyone used a different make and model part as a replacement? I have a flushed / cleaned tank from an '89 wagon. sender/float is clean. Research seems to be that it fits '87 to '89 only. Any reason why this same setup wasn't used in the "carry-over" '90 - '94 Loyale Wagon models? Quote Link to comment Share on other sites More sharing options...
1980ea71Brat Posted May 21, 2022 Share Posted May 21, 2022 (edited) Well I will let you know. Because I just ordered a fuel tank from a 1991 loyale for my 87 RX. So I am going to swap the sending unit at the least. I already swapped in the tach unit and it worked just fine with my 87 sending unit. To clarify my 87 sending unit only works intermittently. But the gauge read full when fully lift and empty when fully lowered. But I will find out if the 91 sending unit fits in a 87 tank Edited May 21, 2022 by 1980ea71Brat Quote Link to comment Share on other sites More sharing options...
1980ea71Brat Posted May 25, 2022 Share Posted May 25, 2022 Just an update - The gas tank I ordered out of a 91 loyale seems to be an exact (or exact enough) replacement to my 87 gas tank and the fuel sending unit looks identical. Also, I had to replace the cluster in mine because the fault was actually the gas gauge itself, and not the sending unit. Hope that helps someone out there. 1 Quote Link to comment Share on other sites More sharing options...
newmexguy Posted June 5, 2022 Share Posted June 5, 2022 Ok - that seems to indicate that the "carryover" Loyales used the earlier tank. Quote Link to comment Share on other sites More sharing options...
