afewsubarus Posted May 9, 2022 Share Posted May 9, 2022 My 2002 non-VDC Bean Outback transmission part#31000AE640 has a non-repairable forward diff. I can source a 2002 transmission part#31000AE800 from a Legacy GT. My question is will this work? The parts diagram I referenced shows that it does. Although the diagram for #31000AE640 shows that transmission only fitting the non-VDC 3.0 cars, not the GT. Seems confusing. I’m in the Northwest. If anyone knows of the whereabouts of a 2002 #31000AE640 non-VDC or even a broken one with a good forward differential I would be most appreciative. I have quite a few old Subarus and some NOS parts I might consider trading for the transmission. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 11, 2022 Share Posted May 11, 2022 Off the top of my head, 4-cyl AT Outback and (I think) GT are 4.444 axle ratios. H6 Outback is 4.111. So you might have to swap rear diffs, as well. www.car-part.com is a very useful tool for finding used parts. Quote Link to comment Share on other sites More sharing options...
wtdash Posted May 11, 2022 Share Posted May 11, 2022 Using Opposedforces, Looks like Numbchux is correct - again. Scroll down to Gear set-hypoid 3.0 OB: http://opposedforces.com/parts/legacy/us_b12/type_27/train/differential_transmission/ = 4.11 GT: http://opposedforces.com/parts/legacy/us_b12/type_4/train/differential_transmission/ = 4.44 But note the Transmission ID / Part Number is different, so YMMV. Quote Link to comment Share on other sites More sharing options...
afewsubarus Posted May 11, 2022 Author Share Posted May 11, 2022 Thanks for confirming my suspicions. Quote Link to comment Share on other sites More sharing options...
