Espey16 Posted May 17, 2022 Share Posted May 17, 2022 I know there's a ton of threads discussing this topic, I just can't seem to figure out the search feature. Anyway, a few years ago my TPS decided to crap out. I couldn't find any EA82 Subies at the junk yard, so I found a TPS at autozone that was for a completely different vehicle but it was the same as our TPS. Only issue was it had a pigtail connected to it instead of a male connector. I cut the wires on it, and the female connector off my wire harness and soldered the wires together. Car fired right up and quit doing what it was before. Since then my mileage has dropped significantly and I think this might be the culprit. Looking at the book, it shows the TPS wiring unhooked when you're supposed to calibrate it. Can I still calibrate this one even though it's hard wired in? Thank you for suffering through this super long post. Quote Link to comment Share on other sites More sharing options...
Espey16 Posted May 17, 2022 Author Share Posted May 17, 2022 BTW the TPS I'm talking about is Autozone pn: TPS4085 Quote Link to comment Share on other sites More sharing options...
DaveT Posted May 17, 2022 Share Posted May 17, 2022 It might work... be safest to disconnect the cables from the ECU, and the battery negative. Quote Link to comment Share on other sites More sharing options...
