Issac Posted June 8, 2022 Share Posted June 8, 2022 It worked fine the other day but now all of a sudden it just starts pulsing and acting up and I'm not sure if it's accurate Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 9, 2022 Share Posted June 9, 2022 It could be a broken speedo cable. Worst case it’s the plastic gear in the gearbox stripping out. If the speedo cable isn’t it, the easiest fix is to use a GPS for speed readings. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
ferp420 Posted June 10, 2022 Share Posted June 10, 2022 (edited) try some wd40 inside the speedo cable its worked for me a few times on other vehicles ive pulled the cable out of the sleeve and cleaned and regreased it and they worked good after you might need to pull the cable from the trans side i cant remeber how the loyal spedo cable works Edited June 10, 2022 by ferp420 Quote Link to comment Share on other sites More sharing options...
