torpedo51 Posted June 21, 2022 Share Posted June 21, 2022 (edited) Hi, I'm rebuilding my EA81, and I can't seem to figure out what year it was made so that I can order accurate rebuilt parts (gasket set, bearings, etc) Its currently part of a VW bus project... I don't have any record of any prior Subaru VIN. I can try to obtain pictures of the head gasket mating surfaces, and whatever casting codes are present. I think we tried to find casting codes before, and didn't see anything definitive that linked the case to a year/make/model. Is there anything else that will help me? I have a few service manuals, but I don't see a section for "identifying" the engine. Thanks! 67752945031__5E29556E-25BA-445B-B443-537F138297CA.HEIC Edited June 21, 2022 by torpedo51 added photo Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 21, 2022 Share Posted June 21, 2022 There’s not much to identify with these engines other than differences in the heads. The valve covers determine if you have the small or larger valve heads. Black is the later heads with the larger valves, aqua type colour is smaller valves. Other than that difference gaskets and bearings etc will all be the same, maybe with exception to the carb if they changed the carb at all during the production run. I’m not 100% on that though. I do know really early EA81s came with a single throat carb, apparently these weren’t produced for long. Someone else will clarify. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
torpedo51 Posted June 21, 2022 Author Share Posted June 21, 2022 Thanks for the reply. I don't trust the valve covers (no stickers, been painted). I see a few threads here that have some tidbits... the trend that I think that I see is a single break in production 1980-1981, and 1982-1989. I'm wondering what the change was between 81 and 82. I think mine has hydraulic lifters. The intake manifold that I have is custom (its a 1982 GM TBI). -- T Quote Link to comment Share on other sites More sharing options...
Steptoe's photos Posted June 22, 2022 Share Posted June 22, 2022 see any round marks in casting of block halves ? I think EA81 had them and will have a two digit like 84 If you think you have hydraulic lifters .. I seem to recall my hydraulic liftered EA81 imported from Japan had mild steel push rods, whereas our standard in Australia was solid lifters and they used aluminium tube with steel ends capped the alloy tube for push rods. Quote Link to comment Share on other sites More sharing options...
Steptoe's photos Posted June 22, 2022 Share Posted June 22, 2022 There were different standard head castings over the years and the earlier heads used slightly smaller valves.Some had what could be described as flat braces seen on the top side between central area and outer as if to brace where inlet manifold bolts on. So much of these is so common, it might be your luck to get something different. HGs the same right through EA81 carb models. Can you add a pic of the head spark plug side to a post ? Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 23, 2022 Share Posted June 23, 2022 On 6/22/2022 at 9:26 AM, torpedo51 said: The intake manifold that I have is custom (its a 1982 GM TBI). Is this that yellow painted engine from the kombi conversion that was the topic of discussion asking about the TBI system on the EA81? Cheers Bennie Quote Link to comment Share on other sites More sharing options...
torpedo51 Posted June 23, 2022 Author Share Posted June 23, 2022 22 minutes ago, el_freddo said: Is this that yellow painted engine from the kombi conversion that was the topic of discussion asking about the TBI system on the EA81? Cheers Bennie Yep! 1 Quote Link to comment Share on other sites More sharing options...
torpedo51 Posted July 5, 2022 Author Share Posted July 5, 2022 Here's some pics of a cylinder head. See anything useful? Pictures of lifters to follow. Quote Link to comment Share on other sites More sharing options...
torpedo51 Posted August 16, 2022 Author Share Posted August 16, 2022 Found hydraulic lifters during the build, so now I'm thinking its an 1984+ ?? Quote Link to comment Share on other sites More sharing options...
Steptoe's photos Posted August 20, 2022 Share Posted August 20, 2022 I have or had some heads that look like this. That "webbing" with grid line squares style embossing between head bolt holes is what makes them stand out as not so common among the EA81 stuff I have had. If I have one set, it might be they were my only hydraulic liftered EA81. The push rods are all mild steel whereas solid liftered have alloy rod, steel end caps. I also suspected these heads were the smaller inlet valve version. Peeps might say get the bigger valve heads, but 1.0mm increase? Really ? Can 1.00mm make all that much difference ? If you have hydraulic, it may be worth sending to Mizpah Engineering to get them reconditioned. I have a set of their work in one of my EA82 engines, great stuff Quote Link to comment Share on other sites More sharing options...
