gorgeguy Posted December 6, 2022 Share Posted December 6, 2022 When the cruise is on I get a periodic beep. It sometimes is 5 or 10 minutes between beeps and sometimes it will beep two or three times in a minute. When the cruise is disengaged there is no beep. any ideas???? Quote Link to comment Share on other sites More sharing options...
brus brother Posted December 6, 2022 Share Posted December 6, 2022 Sounds like a "feature" related to eyesight settings. Google "subaru beeps under cruise control" LINK and you'll see a bunch of links and remedies. Better yet, ask SOA for their explanation. You should still be under warranty? Quote Link to comment Share on other sites More sharing options...
heartless Posted December 6, 2022 Share Posted December 6, 2022 agree that asking SOA, or even your dealer, would be the best option with this new of a vehicle. that said, i would be inclined to agree it has something to do with the eyesight settings - my partner just recently got a 2017 Mazda and it would beep in certain conditions as well, all related to the lane assist stuff (blind spot & lane wandering warnings) and the cruise control (getting too close to the vehicle ahead of you). He found that the beeping could be turned off in the settings. Quote Link to comment Share on other sites More sharing options...
gorgeguy Posted January 18 Author Share Posted January 18 The dealer was clueless as to what was causing it. I took the tech for a ride and he heard it beep four times in a 10 mile drive. I made an appointment to have it looked at but got to messing around with the settings and turned off as much of the "eye sight" as I could and no more beeping. I cancelled my appointment. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 18 Share Posted January 18 34 minutes ago, gorgeguy said: The dealer was clueless as to what was causing it. I took the tech for a ride and he heard it beep four times in a 10 mile drive. I made an appointment to have it looked at but got to messing around with the settings and turned off as much of the "eye sight" as I could and no more beeping. I cancelled my appointment. It beeps when you're approaching another object at a high rate of speed. If you have heavy feet on both pedals or are in congested areas it's going to beep a lot as you outpace the slower vehicles in front of you. It'll also beep if a vehicle is coming up behind you quickly around the blind spot and it receives steering input similar to a lane change. At first the side view mirror lights flash to grab your attention but ramps up to beeping if it escalates. Quote Link to comment Share on other sites More sharing options...
Suzam Posted Monday at 06:59 PM Share Posted Monday at 06:59 PM There is a feature that has an alert whenever the speed limit changes as a warning when you enter a different speed limit or exceed the posted limit. Is what you're hearing a beep similar to when the eyesite locks in or a different tone? 1 Quote Link to comment Share on other sites More sharing options...
