azdave Posted December 15, 2022 Share Posted December 15, 2022 At 35 years old and 250,000 miles, I know there will always be something on my 87 DL wagon that needs some attention but it sure gets old fixing the new stuff I just installed. I don't mind repairing old, worn out parts but it is so irritating when new parts fail after only a few months. I went through at least 3 electric fuel pumps before I found one that was reliable. Now this week it was my 4 month old plastic/aluminum radiator that puked its guts. It cooled better than the very old, leaky brass radiator that came with the car so I was happy I changed it out. Unfortunately, the compression seal on the passenger side tank let go and it opened up a seam about 5'' long and dumped plenty of antifreeze down my driveway. It wasn't an over-pressure issue as the relief cap was new and also tested properly on the bench. I suspect that the rubber seal is low quality and it slowly squeezed out of the joint over time. It could also be that the compression seal was not up to snuff. I ended up repairing the old brass radiator that came with the car and so far, so good. It had 3 small tank leaks that I was able to silver-solder. It passed an overnight pressure test at 15 PSI. The winter season here should be no challenge for any radiator but we'll see in the summer how it does(if it makes it that far). The aftermarket radiator did seem much better at running cooler. My other repair this week was the driver's window crank. I recently became that guy at the drive-through who has to open the door to order and pick up food. I suddenly could not get the window up or down and the crank handle was now at a suspicious angle. That kind of failure is not unexpected with old cars. I was able to remove the window regulator assembly and repair the bushing on the back side of the crank housing with a small steel bushing cap I turned out on the lathe. I was not able to crank the window at all because the coiled spring hidden inside the crank (which helps holds the window in the desired position) had slipped and become wedged tightly between the housing and the crank. I got it all repaired, cleaned, greased and back together late last night. I'll bet the window mechanism hasn't work that well in many years. I'm back to daily driving it to work so we'll see how long until the next adventure begins. 2 1 Quote Link to comment Share on other sites More sharing options...
88SubGL Posted December 15, 2022 Share Posted December 15, 2022 Any possibility of having a new core put in the original radiator? I’m sure it would last much longer than most any aftermarket radiator. 1 Quote Link to comment Share on other sites More sharing options...
azdave Posted December 15, 2022 Author Share Posted December 15, 2022 2 hours ago, 88SubGL said: Any possibility of having a new core put in the original radiator? That will be my next move if this one leaks to the point where I can't repair it or if it can't handle the A/C heat load next summer. I have no idea if modern tube and fin cores would match up or cause fitment issues. I have a shop down the street that builds them but they aren't cheap. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 15, 2022 Share Posted December 15, 2022 what brand was the replacement? any warranty ? Quote Link to comment Share on other sites More sharing options...
newmexguy Posted December 23, 2022 Share Posted December 23, 2022 I have a Replacement Copper / Brass radiator. Near new, but some cosmetic defects. $40. PM if interested. Quote Link to comment Share on other sites More sharing options...
azdave Posted January 3, 2023 Author Share Posted January 3, 2023 On 12/15/2022 at 3:03 PM, 1 Lucky Texan said: what brand was the replacement? any warranty ? It was a Rock Auto deal. I think most of them are from the same vendor with different labels added by the sellers. It had a warranty until I was carrying it into the garage and snapped off the overflow tube when I hit it on the door frame. I was able to fix the overflow tube and then un-crimp, reset the gasket and re-crimp the tank tabs and it has held 15 PSI for over a week so I'll have it as a spare for now. On 12/23/2022 at 8:56 AM, newmexguy said: I have a Replacement Copper / Brass radiator. Near new, but some cosmetic defects. $40. PM if interested. Good price! I appreciate the offer but with my solder repairs holding after several hundred miles and the new "defective" radiator seemingly repaired, I'll go with what I have for now but thanks. Quote Link to comment Share on other sites More sharing options...
azdave Posted January 12, 2023 Author Share Posted January 12, 2023 (edited) I'm pretty much driving this everyday now and have gone almost one month with no new surprise repairs needed! Woohoo! Maybe it's finally getting sorted out a bit. I did add this rooftop carrier box last week but not sure I like the added wind resistance. I might swap to a 45" rooftop basket. BTW...In case you noticed, I added the "SUBARU" stickers myself. That cargo box was originally sold by Sears. Edited January 12, 2023 by azdave Quote Link to comment Share on other sites More sharing options...
88SubGL Posted January 12, 2023 Share Posted January 12, 2023 Nice looking DL! Especially with 250k on it. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted January 13, 2023 Share Posted January 13, 2023 Why do you need to have a pod or basket up top all the time? Isn’t the wagon big enough in its cargo space?? And don’t go making posts about stuff not going wrong, Murphy will take it for a spin and it’ll return with a list of stuff for you to find and resolve!! And I agree with @88SubGL - she’s a beautiful example of the L series! Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Steptoe's photos Posted January 13, 2023 Share Posted January 13, 2023 it is supposedly less wind resistance if you run a small boat on your roof when it's front faces the rear. I wonder if that pod can be turned about for better wind tunnel readings? Quote Link to comment Share on other sites More sharing options...
azdave Posted January 16, 2023 Author Share Posted January 16, 2023 I don't use the carrier box that often but don't like taking it on and off and then storing it some place. I actually have filled the back of the wagon several times recently doing supply runs for work (bulky, lightweight stuff) and needed more room. I think a rack would better serve me and can stay there when it is empty with little effect. It won't need stored off-season and also is easier to load the top since what I put up there doesn't really need rain or theft protection. I'm ordering one of these and giving it a try. The cargo box is up for sale locally for about what it will cost to buy a rack. 1 Quote Link to comment Share on other sites More sharing options...
azdave Posted January 17, 2023 Author Share Posted January 17, 2023 To keep the off-road 4WD theme consistent, I always thought the side of my wagon should display an OEM looking "4WD" logo that matched the ones on the tail gate and the mud flaps. It's been raining here so I spent some time indoors on my cheap eBay laser cutter and came up with this graphic for the left and right rear doors. I also made one to go over the rear logo as it was very sun bleached. It's not perfect but neither am I. 2 Quote Link to comment Share on other sites More sharing options...
azdave Posted January 23, 2023 Author Share Posted January 23, 2023 (edited) Got the new roof rack installed and digging it so far. I did a test run on the freeway last night to see if there were any wind whistles or other distracting noises and I didn't hear anything so it probably will stay there most of the time. I was "rewarded" for my work when I turned on the heater last night after the wife and I were retuning home from dinner and got a blast of humidity and antifreeze odor from the outlets. Really? As expected, I found an area of antifreeze dripping under the dash at the bottom of the heater box so time to research how hard that's going to be to repair. I took a quick look online this morning and don't see anyone selling replacement heater cores either. I'm guessing it is all brass so maybe there is hope I can repair it. Edited January 23, 2023 by azdave 1 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted January 24, 2023 Share Posted January 24, 2023 Plastic end tank on the heater core is leaking. Don’t drive it as they can completely let go (not fun!). Don’t get second hand units, they’ll just do the same, been there done that twice! I managed to get an all copper unit about ten years ago now and haven’t looked back since. To do the swap the whole dashboard has to come out to then pull out the heater box to remove the leaking heater core. Not a hard task, just fiddly then heavy when removing the dash board from the car via the passenger’s side. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
azdave Posted January 24, 2023 Author Share Posted January 24, 2023 9 hours ago, el_freddo said: Plastic end tank on the heater core is leaking. Don’t drive it as they can completely let go (not fun!). Don’t get second hand units, they’ll just do the same, been there done that twice! Thanks for the insight on the repairs and cores. I haven't seen any heater cores available, let alone an all-metal solution. I find them listed for sale many places but when I actually move the part to the shopping cart it becomes "unavailable". I figure I will do a bypass for now so I can keep driving while I search for a solution. I might have to create my own with help from the local radiator shop. 1 Quote Link to comment Share on other sites More sharing options...
azdave Posted March 6, 2023 Author Share Posted March 6, 2023 (edited) The leaking heater core has been bypassed and I likely won't need any heat or defrosters again until next winter so I'm driving it for now and will schedule a fix later. Too many other projects. The repaired aftermarket radiator went back in and has been leak-free for about a month so fingers crossed. We've already been seeing temps in the 80's so time will tell if it makes it through the summer. I found a nice cargo bag at a thrift store and used it over the weekend. It rolls up and fits perfectly in the storage compartment in the floor so a nice fit and under $10. We stopped at a local car show on the way home Saturday and got quite a few people checking out the wagon. https://photos.app.goo.gl/z6vpYcdcHgQgX3C1A Edited March 6, 2023 by azdave 1 Quote Link to comment Share on other sites More sharing options...
czny Posted March 6, 2023 Share Posted March 6, 2023 (edited) https://thebrassworks.net/collections/heater-cores/harrison-78 https://thebrassworks.net/pages/how-long-will-it-take-to-get-my-order 😉 Edited March 6, 2023 by czny Quote Link to comment Share on other sites More sharing options...
azdave Posted March 7, 2023 Author Share Posted March 7, 2023 (edited) 17 hours ago, czny said: https://thebrassworks.net/collections/heater-cores/harrison-78 https://thebrassworks.net/pages/how-long-will-it-take-to-get-my-order 😉 I can't image those parts or repairs would be within my stingy budget but thanks for the links. I have the skills to adapt another heater core if I need to and it looks like that might be what will happen once I get it apart. Edited March 7, 2023 by azdave Quote Link to comment Share on other sites More sharing options...
czny Posted March 7, 2023 Share Posted March 7, 2023 1 hour ago, azdave said: I can't image those parts or repairs would be within my stingy budget but thanks for the links. I have the skills to adapt another heater core if I need to and it looks like that might be what will happen once I get it apart. Adapting a different heater core is what I would do too. Find something with a like sized core, cut off the swaged hose bits & solder on the tubes from the old heater core with copper couplings. I'll need to do this too this summer. Some condensation develops on inside of windshield when parked overnight after running it this winter. It's either the heater core leaking slightly or mice breathing hard. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted March 7, 2023 Share Posted March 7, 2023 8 hours ago, czny said: solder on the tubes from the old heater core with copper couplings. You won’t be able to solder on the tubes from the old heater core - they’re plastic! Both end tanks are plastic. You might be able to solder copper end tanks to the core that’s in there provided that’s not the bit that’s leaking. Bite the bullet, buy the new all copper core, fit it in and never look back! Pull it out before scrapping or selling the vehicle if need be!! Cheers Bennie Quote Link to comment Share on other sites More sharing options...
czny Posted March 7, 2023 Share Posted March 7, 2023 6 minutes ago, el_freddo said: You won’t be able to solder on the tubes from the old heater core - they’re plastic! Both end tanks are plastic. You might be able to solder copper end tanks to the core that’s in there provided that’s not the bit that’s leaking. Bite the bullet, buy the new all copper core, fit it in and never look back! Pull it out before scrapping or selling the vehicle if need be!! Cheers Bennie Yeah Bennie, what meant was to find a copper alloy heater core with brass tubes to solder to. I found one years ago & it's stashed away for the day I finally need it. My old radiator go to shop, Associated Radiator in Covina CA had brass radiator & heater cores on hand for repairs last time I asked about it a year ago. https://associatedautorepair.com/ https://usradiator.com/cores 1 Quote Link to comment Share on other sites More sharing options...
azdave Posted March 8, 2023 Author Share Posted March 8, 2023 Winter lows around here rarely make it to freezing so it is not a big deal to be without cabin heat. I have 3 other classic cars I drive during the winter that haven't had heat for years. When the time comes that I feel like ripping the whole dash out, I'll do a solid repair that will last even the next owner. I'll find an all metal core and make it work. I'll bet that even a small aftermarket oil cooler would be a good candidate to modify. I have several of those around already with different tank configurations. 1 Quote Link to comment Share on other sites More sharing options...
