My horn is possessed.
was driving my parents GM that had same happen. Turned out that due to it's design, a rivet style of construction that anchored horn to the brackt came llose, horn swiveled on bracket causing earth switched electrical contact male spade, to touch the metal bracket, earthing it :)  I think most horns are earth switched, so even the wire rubbing on the body somewhere can trigger them
  • Like 1
On my 1992 Loyale my son used to honk the horn with his fist :).  No surprise that after some time the horn started honking on its own.  I removed the top from the steering wheel, bent down those tabs and it is fine since that.
Worth to try.
Good luck,
Sam
  • Like 1
