djmark7 Posted July 30, 2004 Share Posted July 30, 2004 The Blower in My Legacy is only working on 'high' i think it's the motor itself? any other ideas? also does anybody have any tips or tricks or diagrams on how to replace it? and where i might be able to buy a new resistor unit cheep? Thanks, Mark Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted July 30, 2004 Share Posted July 30, 2004 If it only works on high, i'd say it's the resistor pack. Pull the glove box out, and you should see the resistor pack there. Check the wiring and see if you can get a used one to swap in to verify that's the problem. Quote Link to comment Share on other sites More sharing options...
rweddy Posted July 30, 2004 Share Posted July 30, 2004 If it only works on high, i'd say it's the resistor pack. Pull the glove box out, and you should see the resistor pack there. Check the wiring and see if you can get a used one to swap in to verify that's the problem. I agree. The motors and resistors are very easy to replace, just pull the glove box and you will see them there. Goto the junk yard and you can get one for cheap. Plus if you have a pull it yourself place you can practice pulling apart a junk, as to not damage yours in the process. Quote Link to comment Share on other sites More sharing options...
djmark7 Posted July 30, 2004 Author Share Posted July 30, 2004 Thanks all got A New One from Subie $49.95 cheep lol thnx again Quote Link to comment Share on other sites More sharing options...
djmark7 Posted July 31, 2004 Author Share Posted July 31, 2004 all fixed, that was the easiest thing i did Quote Link to comment Share on other sites More sharing options...
