'79 Brat EJ22 Retrofit Build Thread
Busy workweek this week - but I got some really wonderful weather today and took the opportunity to get the next notable step dealt with - making the threaded mounting points for the impreza diff subframe.  Also before I get too far into it, a  protip/safety tip:  if someone finds themselves recreating this, or if I decide to do it again - make sure you're using plain, non-galvanized tubing. I'm sure someone has spotted that already and was kind enough to keep their yap shut about it 😅  I used what I have on hand and looking back at it the prep work involved to safely weld this stuff with my setup quickly wiped out any minor cash savings I made by not just going to buy another stick of tubing. I'm sure I don't have to go into details about the dangers of working with galvanized material, but it's worth repeating that Zinc is bad for you in gaseous form and if you're gonna encounter it to take the proper safety precautions.
With that out of the way - the photo essay goods:
After everything was tacked up and nominally square - I clamped the new frame in its place on top of the bushings, and marked the first hole location for the threaded inserts ( M16 nuts I'm welding in), then center punched and drilled out the hole. I had access to weld the outer half of the nut since it's pretty close to the end of the tube and I used a technique i learned involving some clever placement of smaller access holes to get the inside faces of the nuts fused in. Like the other channels, this will all get boxed in and closed up when i'm happy with the fitment. After this I continued marking and drilling one hole at a time, using the Impreza subframe as a jig to make sure things ended up where they needed to be. I also drilled these holes slightly oversize so that I have a little wiggle room in their placement. Their final positions were dictated with tacks on the welder and then fully welded off of the impreza subframe so as not to melt or damage the bushings.
After the new weldment and sheet metal subframe were temporarily assembled together, I put the diff back in it, put it on the transmission jack and then bolted the diff to the front mounts under the car.  The original holes and features made for a really handy reference mark and wouldn't you know it, things came out super even. So even in fact, I couldn't help but loosely bolt the lateral links in, prop the trailing arm up, and lean the coilovers (not pictured) up in there without any bolts to get an idea of how things are going to sit.
I can almost see it on the ground again! (It'll still be a while). I don't know if I'll be able to narrow the rear wheelbase quite as much as I'd have originally liked, though with a quick google having a slightly wider rear track isn't uncommon and can actually help with certain handling characteristics. I might have to flare my rear fenders, as I do not think I'm going to be able to reduce the rear width the full 9" (4.5" on each side) or so I originally measured without some pretty significant clearancing wizardry beween subframe and coil. I'll have a better plan of attack here once I've got everything semi-permanently affixed to the frame but either way what this is telling me is that I'll probably need to refrain from fully welding in this frame modification until I've got the suspension completely located. I'm also eyeballing putting in a set of rear discs rather than these drums, as I'm not a huge fan of drum brakes and well... I'm already really in the weeds so why not just do it from the ground up?
Might get a little more in on this over the weekend, but I'll be playing that by ear.
Until the next one!
-M
Edited by mka
