90 Loyale Auto Seatbelt Connector Location?
Fixed :>) I never did find the test connector, but the drivers side motor was disconnected by the previous owner. The door lock connector had broken wires (2 of the 3) as the wires were up against the window support rail. I believe this is why the motor was disconnected. It was most likely doing many strange things.
I've got a 90 Loyale Wagon, 2WD and the auto seatbelts are not working. The fuses are good. I have not been able to find the connector to put the computer in the readout mode.
Anyone know where it is?
I've had both sides of the dash opened and searched all over, no luck. Thanks
Take off the panel of the dash that covers the fuse box and the area above the pedals. There is a small hole on the top edge of the computer. turn the key to on and see if the LED in the hole flashes. If it doesn't, there is possibly 2 green connectors under the hood by the wiper motor. connect them if they exist (mine only has one?), that should kick the readout off.
