Skip Posted November 14, 2004 Share Posted November 14, 2004 This mod was done to mount Subaru center caps on Peugeot 15" alloys. The center caps were from EA82 wheels. I believe other caps will fit and other wheels (Enkei's) can use this adaptation. Simply hold a center cap over the opening to check fit, if it covers the opening you are good to go. These center caps are made from stainless steel, therefore you can "stud weld" a stud to them. http://www.machinedesign.com/BDE/FASTENING/bdefj3/bdefj3_28.html Most good body shops and sign shops have stud welding equipment. I used 10-24 x 0.75" SS studs welded to the inside center of the cap. This afforded a place to fasten an aluminum "wing nut" of sorts. I used cardboard to make a template of the wing shape. It should just about span the opening of the wheel (wedging on the inside lip of the wheel opening) and have a flat in the center. I band sawed 0.090 Al plate for the wing and break formed it to fit my template. (obviously you will need four of these) I then drilled a clearance hole for the 10-24 stud in the center of this flat. Hold center cap centered over hole, bend tabs as necessary to achieve centering. Place wing on stud and secure with nut and lock washer. I also use a small dollop of silicon sealer on the nut/threads to act as lock tight. These have been on for well over 6 months and have never worked loose. Please email me if you have any questions. BTW Tires are 225/50 R15" Quote Link to comment Share on other sites More sharing options...
baccaruda Posted November 14, 2004 Share Posted November 14, 2004 cool! can you take a picture of the cap itself to illustrate your desctiption? Quote Link to comment Share on other sites More sharing options...
Qman Posted November 15, 2004 Share Posted November 15, 2004 I wondered how you did that. I saw the centers when you posted the same pic in the lights post a little while back. Good job! Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted November 16, 2004 Share Posted November 16, 2004 hmmmmmmm I have some good caps floating around and some gen 1, 4 hole alloys floating around........ I like your idea Skip!!! now I can replace the awful centercaps on those things cause they aren't the original caps! Quote Link to comment Share on other sites More sharing options...
Skip Posted November 16, 2004 Author Share Posted November 16, 2004 Thanks for the props guys. Andy, next time I have a wheel off I'll get some picts. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted November 17, 2004 Share Posted November 17, 2004 shanks shkip Thanks for the props guys. Andy, next time I have a wheel off I'll get some picts. Quote Link to comment Share on other sites More sharing options...
