Jeepman775 Posted December 25, 2004 Share Posted December 25, 2004 only one problem Got a ecc fuse that keeps blowing, and gauge cluster idiot lights dead, I can't figure it out, I turn the key and everything is still dead as hell. Anyone got any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
MorganM Posted December 25, 2004 Share Posted December 25, 2004 Sounds like power to the wrong wire. Prolly to a ground accidently? That might explain the poping fuses. That's what I like to hear! "Done" .... or really damn close Quote Link to comment Share on other sites More sharing options...
Jeepman775 Posted December 25, 2004 Author Share Posted December 25, 2004 Yesssssss........ close....... that's it........ that might be one to check but I can't see how that happened because I swapped the whole harness out (had to) this swap was hellish. spfi - mpfi alone requires everything to be change out everything, and I mean that. the bastards even used different heater fan connectors, can ya believe that. but I can't find this one DAMN short. she might have to go see my mechanic friend. By the way do any of you think a short in one the ECC fuse circuit would cause the starter and cluster to be dead? Quote Link to comment Share on other sites More sharing options...
moosens Posted December 25, 2004 Share Posted December 25, 2004 So,pardon me for asking,but would you guys say that if you intend on doing this swap that you'd want to change out the ECU,main harness,whole kit 'n kaboodle?I was planning an MPFI upgrade. Heater connectors too?Sounding like you'd better swap out the dashboards and everything going through the firewall.Just for about what?5 more horsepower??The delivery is smooth from the start,that's what I like.The SPFI is almost like the last carbs they ran......lacking power,but better than the carbs by a good measure. Quote Link to comment Share on other sites More sharing options...
