WJM Posted January 6, 2005 Share Posted January 6, 2005 So i got a TD04 today! Now...im going to work on rotating the housing 90 deg which is supposily impossible...and throw it on the RX as soon as I get intake peices...and maybe a DP. I have a stock WRX DP...but Id like to get something 'real' to put on it. Quote Link to comment Share on other sites More sharing options...
Tachometer Posted January 6, 2005 Share Posted January 6, 2005 I'm sure this has been answered countless times before...but my fingers and brain are cold right now so I'll just ask this again... In order to mount the WRX TD04 into an EA81T you need to... -Rotate the turbo housing 90 deg -use a WRX downpipe (or whatever else uses the same bolt pattern) -??? Is there any trickery required with cooling/oil lines? Or is it really THAT simple? And how about mating the WRX downpipe to the stock exhaust...any tricks with that or is it just bolt on? I've got the downpipe, and have been thinking about this...just haven't pulled any triggers yet. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 7, 2005 Share Posted January 7, 2005 Now...im going to work on rotating the housing 90 deg which is supposily impossible... why does it have to be rotated 90 deg? I've got one coming and so I'm just wondering, I thought is was almost a bolt in item except for the rear bolt on the up pipe....I've got a stock WRX dp with 500 miles on it coming as well:D Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted January 7, 2005 Share Posted January 7, 2005 So i got a TD04 today! Now...im going to work on rotating the housing 90 deg which is supposily impossible...and throw it on the RX as soon as I get intake peices...and maybe a DP. I have a stock WRX DP...but Id like to get something 'real' to put on it. So you have a stock WRX turbo and downpipe. I thought you had a TWE downpipe. What's going on? :-\ Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 7, 2005 Share Posted January 7, 2005 TWE downpipe will fit the stock IHI RB5 turbo, not the TD04. The TD04 has a different bolt pattern on the exit side so they don't match up. Quote Link to comment Share on other sites More sharing options...
WJM Posted January 7, 2005 Author Share Posted January 7, 2005 the coolant lines need to be 'adjusted' and the downpipe and up pipe/header flange is different...but NOT on the TWE pipes, they fit both the new and old IHI's. the oil lines look to be the SAME. the compressor housing will not line up to anything stock. where the stocker has a 90* elbo cast peice on it...the TD04 does not, you will have to fasion a new pre-turbo intake. as for the compressor outlet...the stocker is pointing UP. the td04 points, towards the TB horizontally. that has to be adressed with new piping, or moving the wastegate actuator along with rotating the housing to its exiting UP. Quote Link to comment Share on other sites More sharing options...
WJM Posted January 7, 2005 Author Share Posted January 7, 2005 TWE downpipe will fit the stock IHI RB5 turbo, not the TD04. The TD04 has a different bolt pattern on the exit side so they don't match up. exactly. Quote Link to comment Share on other sites More sharing options...
JWX Posted January 7, 2005 Share Posted January 7, 2005 so what are you going to do with the TWE peice? Quote Link to comment Share on other sites More sharing options...
WJM Posted January 7, 2005 Author Share Posted January 7, 2005 so what are you going to do with the TWE peice? Keep it. Its rare dude. 1 of 10~20 world wide. Quote Link to comment Share on other sites More sharing options...
