mcbrat Posted December 19, 2005 Share Posted December 19, 2005 bump Quote Link to comment Share on other sites More sharing options...
richierich Posted December 24, 2005 Share Posted December 24, 2005 Just to let you know, World Pac who owns Redline, says that they are starting making more carbs, I got a price quote on a 32/36 DGEV for $310, they do not have the set up with adapter and filter yet but is going to let me know. Quote Link to comment Share on other sites More sharing options...
Jibs Posted February 11, 2006 Share Posted February 11, 2006 I have a question again. I have installed my weber and went to get the throttle cable on, but it seems to be like an inch too short. I may have to buy a new one, is it gonna fit? Is there a cable I can get thats a little longer than the stock one? Thanks. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted February 11, 2006 Share Posted February 11, 2006 I have a question again. I have installed my weber and went to get the throttle cable on, but it seems to be like an inch too short. I may have to buy a new one, is it gonna fit? Is there a cable I can get thats a little longer than the stock one? Thanks. it should fit no problem... well, the one that came with the hitachi carb fits. not sure if the carter-webber one fits. I've had to take it out of the holder under the spare tray before to get some length.... Quote Link to comment Share on other sites More sharing options...
Jibs Posted February 11, 2006 Share Posted February 11, 2006 It definitely has room behind the throttle linkage, where the cable screws into the linkage is where the room is nulled. Could I cut some of the plastic housing away from the cable to back the tightener up towards te firewall any? I may have to take a picture trying to explain this one. Quote Link to comment Share on other sites More sharing options...
El Toro Posted March 22, 2006 Share Posted March 22, 2006 don't know if any one is still looking at this thread but i have a Webber question. in the thread there is a list of donor vehicles that have carbs that will work on a subie, one is the dodge D50 pickup. i scored the carb from one of these and i can not find a weber badge on it anywhere. i did find the name MIKUNI corp. is this still a carb i can use? and if so where can i locate a adapter plate. EL TORO Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted March 22, 2006 Share Posted March 22, 2006 I would hafta say no and I would recommend selling that Mikuni back to the yard or scrap it cause they are worthless (don't ask bad experiences with Mikuni's on mopar products) Quote Link to comment Share on other sites More sharing options...
El Toro Posted March 22, 2006 Share Posted March 22, 2006 uh Quote Link to comment Share on other sites More sharing options...
El Toro Posted March 22, 2006 Share Posted March 22, 2006 dang.......any other donors you would recommend? i have family near you near where they load the iga trucks...i know bad landmark Quote Link to comment Share on other sites More sharing options...
scrap487 Posted March 22, 2006 Share Posted March 22, 2006 hmm... well I know its not on a subaru, but it IS a weber... swapped an l20b to replace a blown z24 in my 720 truck... it came with a weber 32/36 dgv carbuerator jetted for a 1600 engine(not sure about air, but the fuel jetting is 160 main and secondary is 135). anyways, the problem we are having is the engine will not idle or hardly even run without the choke fully closed, it starves for fuel. we figured the jetting on it would probably be fine for the l20 engine, but the only thing we can come up with that might be causing it is that it doesnt sit completely level, but after adjusting the float we figured that wouldnt be a problem. there are absolutely no vac leaks or anything around the base of the carb or around the manifold, and the ignition is in prime condition tuned dead on. we cant figure anything out and because of this my dad is convinced webers are the worst carbuerators in the world and now he wants to try to make the hitachi off of the z24 work and he is convinced the hitachi is a much higher quality carbuerator. anyone wanna help me with this? Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted March 22, 2006 Share Posted March 22, 2006 where in p-town are you if in the NE area might goto RichieRich's shop over on Prescott and 82nd and it is called SIR inc. they can help you with your weber Quote Link to comment Share on other sites More sharing options...
coylethebarbarian Posted March 26, 2006 Share Posted March 26, 2006 I've read through this post, and some of the links. I am new to carbs...my brat has a weber installed on it...has great gas milage-28mpg, but my engine "diesels" when shut off, I also lose power and the engine "misses" in damp and/or cold weather, especially on large hills. Here is my question, my weber says "DGAV33" (could be DGAV 38 if the stamps are on top of each other...but we'll go with the 33) Where do I find info, diagrams, parts for this weber? I have looked on the web and not had any luck today! Thanks Quote Link to comment Share on other sites More sharing options...
Mike W Posted March 26, 2006 Share Posted March 26, 2006 I'm no Weber guru but I don't think there was ever a 38 DGAV and if that's what you had I don't think you'd be getting 28 MPG. Any chance it says "DGAV32" or "DGAV 32/36"??? That'd be a lot more likely and you'd find more info searching for one of those. This list here shows that a DGAV 32 exists and apparently was stock on Euro Fords. For tuning info and diagrams you might try RedlineWeber.com If the tuning is perfect and it still diesels, you might try adding an anti-diesel solinoid (available from Redline and other folks.) Hope that helps a bit. Post pics of it if you can. Quote Link to comment Share on other sites More sharing options...
coylethebarbarian Posted March 27, 2006 Share Posted March 27, 2006 I'm no Weber guru but I don't think there was ever a 38 DGAV and if that's what you had I don't think you'd be getting 28 MPG. Any chance it says "DGAV32" or "DGAV 32/36"??? That'd be a lot more likely and you'd find more info searching for one of those. This list here shows that a DGAV 32 exists and apparently was stock on Euro Fords. For tuning info and diagrams you might try RedlineWeber.comIf the tuning is perfect and it still diesels, you might try adding an anti-diesel solinoid (available from Redline and other folks.) Hope that helps a bit. Post pics of it if you can. It is possible the stamping is difficult to read, I will check it out yet again tomarrow. I have seen pics of the "DGAV32 & 32/36" and it does resemble those. I'll check out the links & see if I can get some clear pics tomarrow then post them...Thanks for the tips:headbang: Quote Link to comment Share on other sites More sharing options...
Jibs Posted September 3, 2006 Share Posted September 3, 2006 How much fuel pressure can the weber handle? Anyone try getting a little more fuel to their weber? Quote Link to comment Share on other sites More sharing options...
mcbrat Posted September 3, 2006 Share Posted September 3, 2006 How much fuel pressure can the weber handle? Anyone try getting a little more fuel to their weber? it's not the pressure you need to change, it's the size of the jets. the "standard" weber set-up for soobs has 140 mains. I have run 155's before, and it worked well. Never came up short of fuel. too much fuel, and you'll have to rev too high to keep the engine going... (my little Holley 600 cfm experiment). Quote Link to comment Share on other sites More sharing options...
Jibs Posted September 3, 2006 Share Posted September 3, 2006 it's not the pressure you need to change, it's the size of the jets. the "standard" weber set-up for soobs has 140 mains. I have run 155's before, and it worked well. Never came up short of fuel. too much fuel, and you'll have to rev too high to keep the engine going... (my little Holley 600 cfm experiment). So would it be safe to run a 3/8" line form the tank to the carb? Instead of through the hard lines? And would it be possible to run a bigger fuel pump with a seperate fuel pressure regulator in between? Quote Link to comment Share on other sites More sharing options...
mcbrat Posted September 3, 2006 Share Posted September 3, 2006 So would it be safe to run a 3/8" line form the tank to the carb? Instead of through the hard lines? And would it be possible to run a bigger fuel pump with a seperate fuel pressure regulator in between? I have a aftermarket pump on my red brat, solely because it sat for maybe 13 years before I got it.... the pump I got is already at the correct pressure for the weber. I have used a higher pressure pump in the past with a seperate regulator (dial type, supposedly high failure rate). but there was no difference in performance... again, I only used it because of a dead stock pump.... Quote Link to comment Share on other sites More sharing options...
mcbrat Posted September 14, 2006 Share Posted September 14, 2006 well, I got my Brat running again tonight... I had the engine out to do a clutch job, and decided to put in my 155 mains. then along with that, I finally figured out my wiring to run my MSD6A multi-spark ignition... WOW! just running it in the garage, feels/sounds way better.... Quote Link to comment Share on other sites More sharing options...
robm Posted September 14, 2006 Share Posted September 14, 2006 Higher pressure pumps don't help with carbs. As long as the float bowl stays full, it is enough. More pressure can't affect the mixture. Quote Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted September 15, 2006 Share Posted September 15, 2006 well, I got my Brat running again tonight... I had the engine out to do a clutch job, and decided to put in my 155 mains. then along with that, I finally figured out my wiring to run my MSD6A multi-spark ignition... WOW! just running it in the garage, feels/sounds way better.... that rocks i want 1 so bad. Quote Link to comment Share on other sites More sharing options...
crazy D Posted September 29, 2006 Share Posted September 29, 2006 well, I got my Brat running again tonight... I had the engine out to do a clutch job, and decided to put in my 155 mains. then along with that, I finally figured out my wiring to run my MSD6A multi-spark ignition... WOW! just running it in the garage, feels/sounds way better.... are those the spark plugs that have like twin tips? Quote Link to comment Share on other sites More sharing options...
mcbrat Posted September 29, 2006 Share Posted September 29, 2006 are those the spark plugs that have like twin tips? No, it's a separate control box for the disty/coil http://www.msdignition.com/ignition_4_6200.htm Quote Link to comment Share on other sites More sharing options...
Jibs Posted October 10, 2006 Share Posted October 10, 2006 Are there any better aftermarket filters that work better than the one that comes with it? Pre-filter? It seems that I have to rebuild my weber already, its been on for about 90 days and on about 3 offroad trips. Gas is getting to the carb but is dripping into the carb, I think the jets are clogged real bad. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted October 10, 2006 Share Posted October 10, 2006 Are there any better aftermarket filters that work better than the one that comes with it? Pre-filter? It seems that I have to rebuild my weber already, its been on for about 90 days and on about 3 offroad trips. Gas is getting to the carb but is dripping into the carb, I think the jets are clogged real bad. what size are your jets? have you dumped a can of seafoam in the gas tank yet? Quote Link to comment Share on other sites More sharing options...
