alaskansubaru Posted February 18, 2005 Share Posted February 18, 2005 Help I have a problem with my headlight, its dim on low beam and goes out on high beam. It's a new bulb and a new fuse. Quote Link to comment Share on other sites More sharing options...
Ross Posted February 19, 2005 Share Posted February 19, 2005 I Would start by looking for a bad earth. I presume it is an ea82 style (you said new bulb), in which case i have no idea where that earth is! Quote Link to comment Share on other sites More sharing options...
Snowman Posted February 19, 2005 Share Posted February 19, 2005 Do both headlights do this, or is it just one?Start with the simple stuff....check the ground connections first as I think that's the most likely culprit. Just look around at the wiring going to the lights to see if anything looks old, corroded, or otherwise problematic. Quote Link to comment Share on other sites More sharing options...
alaskansubaru Posted February 19, 2005 Author Share Posted February 19, 2005 Do both headlights do this, or is it just one?Start with the simple stuff....check the ground connections first as I think that's the most likely culprit. Just look around at the wiring going to the lights to see if anything looks old, corroded, or otherwise problematic. Its just right headlight. I couldnt find any problematic wires. Quote Link to comment Share on other sites More sharing options...
Snowman Posted February 19, 2005 Share Posted February 19, 2005 Hrm, do you have a volt/ohm meter? The next step is to start checking stuff with one of those to see if you're getting good power and if the ground circuit has minimal resistance. If you don't have a meter, you can get cheap ones that work fine for stuff like this for around $20. Probably the most worthwhile tool you'll ever buy. Quote Link to comment Share on other sites More sharing options...
Skip Posted February 19, 2005 Share Posted February 19, 2005 Sir, your headlights work on a ground control configuration. In laymen's terms this correlates to The element you want to light is provided a ground or negative power reference via the lighting hi/low control on the steering column. The common terminal on the lamp is provided the positive reference via the lighting relay. Which for safety reasons are divided left and right, each having their own relay. This is opposite to what "normal" American cars use. These provide the positive reference to the beam you want to lite and ground the common terminal of the hi/lo beam lamp. If any of this makes sense to you. Please reply . Quote Link to comment Share on other sites More sharing options...
hops Posted February 19, 2005 Share Posted February 19, 2005 check your relays. Klaus Quote Link to comment Share on other sites More sharing options...
alaskansubaru Posted March 4, 2005 Author Share Posted March 4, 2005 It took a bit but I got it fix. It was two problems, 1. bad ground 2. bad relays. I like to thank you all for helping me out. Quote Link to comment Share on other sites More sharing options...
incognito Posted March 6, 2005 Share Posted March 6, 2005 If you don't have a meter, you can get cheap ones that work fine for stuff like this for around $20. Probably the most worthwhile tool you'll ever buy. Stay away from these. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted March 6, 2005 Share Posted March 6, 2005 yo my car does the same thing, but dim on both hi and lo. been too lazy to check it out. ol skip saves the day. where are the relays? you think i would know already being miles fox, but like i said im lazy..like a fox Quote Link to comment Share on other sites More sharing options...
Frank B Posted March 6, 2005 Share Posted March 6, 2005 I agree, it's your relay(s). When they went south on my 86 hatch it affected all the lights, I had no taillights. Also, I found a match out on the shelf in Autozone that were a Pilot Driving light replacement relay that was a 30 amp, instead of the stock 20 amp. They wanted $9.99 at the counter for the OE replacement, the Pilot relays were $3.69 each. Same plug, same size, and works great. Quote Link to comment Share on other sites More sharing options...
Skip Posted March 6, 2005 Share Posted March 6, 2005 I agree to disagree If both headlights are affected..... I find it hard to believe both relays went south simultaneously. I would put my check mark beside the ground point for both headlights or the "R" fusible link connection (this FL feeds the headlamp current to the relays.) These points are common to both headlights and if one of them is not making the trip, both headlamps will be dim. Plus they are both much easier to access than the relays are. Quote Link to comment Share on other sites More sharing options...
Frank B Posted March 6, 2005 Share Posted March 6, 2005 well, I had no taillights, no liscence plate lights, no parking lights, on low beam the left side lamp low beam lamp would be on, the right lamp was very dim. On high beam all 4 lamps were on, but very dim. After replacing the relay's, it all worked fine. Quote Link to comment Share on other sites More sharing options...
Skip Posted March 6, 2005 Share Posted March 6, 2005 Frank, I am sorry I did not mean to "dis" your fix Well done and I am glad it solved your problem. I guess what I was intending was that I would adopt the KISS principle before condemning the relays. Once again I'm sorry it was not meant as an affront. incidentally the parking lights (including the license plate and dash illumination) are fed their positive battery voltage from the right hand headlamp relay Quote Link to comment Share on other sites More sharing options...
hops Posted March 6, 2005 Share Posted March 6, 2005 Frank, I am sorry I did not mean to "dis" your fixWell done and I am glad it solved your problem. I guess what I was intending was that I would adopt the KISS principle before condemning the relays. Once again I'm sorry it was not meant as an affront. incidentally the parking lights (including the license plate and dash illumination) are fed their positive battery voltage from the right hand headlamp relay Skip, is it the parking lights or the taillights? When the problem arises on my loyale and I flick the parking light switch my rear parking lights come on. Klaus Quote Link to comment Share on other sites More sharing options...
Skip Posted March 6, 2005 Share Posted March 6, 2005 Klaus, the "parking lights" I mention include the tail lights. As for your flicking of the light switch fixing the problem possibly the contacts in the lighting switch are going bad and the on/off/on sets them to a full contact position. It must be noted that the these lights (parking, tail ect.) are controlled by a separate set of contacts in the lighting switch. These lights are controlled the "conventional. way" By this I mean one leg of the lamp is grounded and to illuminate the lamp the switch provides the positive voltage. This is not the case with the headlamps, see above. Quote Link to comment Share on other sites More sharing options...
hops Posted March 6, 2005 Share Posted March 6, 2005 Skip, You may have misunderstood my reply. The dim headlight, no taillight and no dashlight problem is related because they all are on the same circuit. Naturally, when you turn on the lights (as in driving lights) you're not turning on the parking lights. The parking lights are turned on by a separate switch. When you have the "dim light syndrome" flicking the parking light switch on is not a "fix", it's merely a way to get you home safely. Therefore, the parking light circuit must be different from the driving light circuit. Possibly because the parking light circuit bypasses the headlight relays. Now, you may turn on the same light bulbs in the taillights when turning on the parking lights, but you're still supplying them with electricity thru a different circuit. I have had the "dim left headlight syndrome" twice and both times the problem was in the relays. Please correct me if I'm wrong. Klaus Klaus, the "parking lights" I mention include the tail lights. As for your flicking of the light switch fixing the problem possibly the contacts in the lighting switch are going bad and the on/off/on sets them to a full contact position. It must be noted that the these lights (parking, tail ect.) are controlled by a separate set of contacts in the lighting switch. These lights are controlled the "conventional. way" By this I mean one leg of the lamp is grounded and to illuminate the lamp the switch provides the positive voltage. This is not the case with the headlamps, see above. Quote Link to comment Share on other sites More sharing options...
Skip Posted March 6, 2005 Share Posted March 6, 2005 Klaus We are both saying the same thing I believe. I was replying to Miles's post - both lamps dim (please see the subject I put onto the reply) Not the original post that had one dim lamp. The parking lights do have a separate set of contacts and therefore you could say a separate switch, inside the headlight control.. But the voltage for both come from the RH headlamp relay. Maybe this diagram will explain what we mean Quote Link to comment Share on other sites More sharing options...
Frank B Posted March 6, 2005 Share Posted March 6, 2005 Frank, I am sorry I did not mean to "dis" your fixWell done and I am glad it solved your problem. I guess what I was intending was that I would adopt the KISS principle before condemning the relays. Once again I'm sorry it was not meant as an affront. incidentally the parking lights (including the license plate and dash illumination) are fed their positive battery voltage from the right hand headlamp relay Nor was it my intention to reply as if correcting you Skip, just wanted to share the knowledge, and describe the symptoms. Quote Link to comment Share on other sites More sharing options...
hops Posted March 7, 2005 Share Posted March 7, 2005 Hey Skip, We're getting closer. My experience comes from a '90 Loyale. It seems that in my car everything is hooked up through the left headlight relay, but that is not important. I could also be wrong, I haven't looked at my wiring diagram in a while. However, If you follow the lead from the parking light switch, it goes directly through a 15 amp fuse and a fusible link to the positive terminal of the battery. Also, the parking light switch is a separate unit from the headlight switch. At least in my wagon it's a little rocker switch on top of the steering column. Now an interesting question is: What makes the relays go out? Is it a bad ground? If so, where is the ground for the relays located in the car? Frank B. mentioned that he bought a 30A (?) relay at an autoparts store that fit. Is that a smart thing to do or would you put a lot of strain on your harness if you do that? Interesting thread. Thanks, Klaus KlausWe are both saying the same thing I believe. I was replying to Miles's post - both lamps dim (please see the subject I put onto the reply) Not the original post that had one dim lamp. The parking lights do have a separate set of contacts and therefore you could say a separate switch, inside the headlight control.. But the voltage for both come from the RH headlamp relay. Maybe this diagram will explain what we mean Quote Link to comment Share on other sites More sharing options...
hops Posted March 7, 2005 Share Posted March 7, 2005 [quote I was replying to Miles's post - both lamps dim (please see the subject I put onto the reply) I think Miles just said that he has a problem on low and high beam, not both lights. Klaus Quote Link to comment Share on other sites More sharing options...
royboy159 Posted March 7, 2005 Share Posted March 7, 2005 It took a bit but I got it fix. It was two problems, 1. bad ground 2. bad relays. I like to thank you all for helping me out. I like to thank you for coming back to post your solutions. I'm wondering though - did you use a meter to check out the circuits? Quote Link to comment Share on other sites More sharing options...
Cougar Posted March 7, 2005 Share Posted March 7, 2005 To Hops: In answer to your question about replacing the 20 amp relay with a 30 amp relay and causing an extra load to the system. The higher value relay should have better switch contacts to carry the load current but that current will only change if you add more load to the circuit the relay is controlling, like more lights. The amp rating refers to the contacts in the relay. The relay coil, that operates the relay, only requires a very small amount of current to make it operate. Quote Link to comment Share on other sites More sharing options...
alaskansubaru Posted March 7, 2005 Author Share Posted March 7, 2005 I like to thank you for coming back to post your solutions. I'm wondering though - did you use a meter to check out the circuits? I found that the ground wire was bad I fix it then I did something and BAM both headlights dim on low then out on high, realy bad for driveing in Alaska at 5:30am (Its realy black with out headlights) so when the cop pulled me over (I had my hazards going) I had to take it the shop (it was going there any way but I ended up with a cop ecort; not the way I wanted to start off my Monday) and they said the relay was bad but that I did good on fixing the bad ground. This all cost me $50 shop time and a $50 fix-it ticket and a $20 cab ride to and from work. What fun! Quote Link to comment Share on other sites More sharing options...
