toybuilder Posted August 28, 2003 Share Posted August 28, 2003 Does anyone know how to remove the oil pickup tube on an EA82 engine without damaging it? Quote Link to comment Share on other sites More sharing options...
GLCraig Posted August 28, 2003 Share Posted August 28, 2003 You might be able to heat up the surounding area of the block and get it out. Quote Link to comment Share on other sites More sharing options...
MorganM Posted August 28, 2003 Share Posted August 28, 2003 One inch chisel and BFH I was really sketchy about pulling mine when I was rebuilding my EA8 SPFI. It didnt seem right but if you work with the angle its stuck in there and pound it out she should move smoothly with every wack. Putting it back in was just as crazy as it had to be pounded back in the same way. Just be sure your wacking on the tube and not your soft aluminum block! Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 28, 2003 Share Posted August 28, 2003 tap on it lightly to try and rotate it one way otr the other, back and forth, and pull up on it as it turns to try an d free it. is just a snug fit Quote Link to comment Share on other sites More sharing options...
