NorthWet Posted March 5, 2005 Share Posted March 5, 2005 it works on a race fiat 1500cc alloy blocks one of our clients at work come and got some 0.6mm stainless mig wire to use for his block which was being machined for it at the time,it worked perfectly and he hasn't had a problem with blown HG's for 2 years now1500cc fiat 14.5CR N/A Does your client run without standard HG or HG w/o-ring? If without, does he/she run a dry deck or o-ring the oil/water passages? Quote Link to comment Share on other sites More sharing options...
oddcomp Posted March 5, 2005 Share Posted March 5, 2005 hell of alot better than i coulda said o wet one and from what i know o ringing involves cutting a groove around the cylinder and then installing a wire of some size jast just a few thousandth of a inch above the deck surface btw since we are talking about killer motors the vnt turbo is sposed to arrive on the 7th... wootness now to find someone to weld cast iron or i can attempt it i spose Quote Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted March 5, 2005 Share Posted March 5, 2005 Does your client run without standard HG or HG w/o-ring? If without, does he/she run a dry deck or o-ring the oil/water passages? he got some HG material and cut out a gasket himself i do remember the gasket material had wire mesh reinforcing Quote Link to comment Share on other sites More sharing options...
NorthWet Posted March 6, 2005 Share Posted March 6, 2005 I ran across cylinder o-ringing back during my first go-round with turbos... back in the mid-70s. Most people then either went dry-deck or used separate o-rings for the water/oil passages. They were also doing it mostly with castiron blocks/heads (usually in the head, IIRC), and using copper wire (better crush). Quote Link to comment Share on other sites More sharing options...
americanyouth Posted March 6, 2005 Share Posted March 6, 2005 Northwet, thanks for the heads up on the management. Exactly what control does this setup afford? Also, why MAP over MAF? I've heard the opposite is more tunable. Quote Link to comment Share on other sites More sharing options...
subyrally Posted March 6, 2005 Share Posted March 6, 2005 shadow, you are absolutly amazing. once again, i get new ideas everytime i see this thread, especially when shadow is posting. i need ms and edis. i want em soo bad now. Quote Link to comment Share on other sites More sharing options...
