Kraven Posted March 8, 2005 Share Posted March 8, 2005 Hi Been meaning to ask about this for a while now. The hot air pipe is not in good shape, busted in quite a few spots and not connected to the stove pipe. What kind of problems am I likely to run into and assuming I buy a new pipe where is the stove pipe that its supposed to connect to, I cant figure it out from my haines manual. 86 gl wagon Thanks Quote Link to comment Share on other sites More sharing options...
moosens Posted March 8, 2005 Share Posted March 8, 2005 Your Y pipe should have a small tube rising up from around just before the cat.on the passenger side.One end of the flex tube goes on there...other on the airbox...you know the deal. Quote Link to comment Share on other sites More sharing options...
Kraven Posted March 9, 2005 Author Share Posted March 9, 2005 Your Y pipe should have a small tube rising up from around just before the cat.on the passenger side.One end of the flex tube goes on there...other on the airbox...you know the deal. Hi again Ive found a rubber pipe in that area which isnt connected to anything it blows air when the engine in running is this it? thanks Quote Link to comment Share on other sites More sharing options...
archemitis Posted March 9, 2005 Share Posted March 9, 2005 is it carbureted? it sounds like a breather hose, or an air suction valve. it should be hooked up to something. if not a pcv, a filter. the only thing not having the air cleaner heater tube hooked up to the exhaust, is that it'll take a bit longer to warm up. i never have them hooked up Quote Link to comment Share on other sites More sharing options...
moosens Posted March 9, 2005 Share Posted March 9, 2005 If it's a large diameter hose it probably goes to the "trombone" pipe at the top of the intermediate pipe (longer mid-pipe) just rear of your tranny. Quote Link to comment Share on other sites More sharing options...
Kraven Posted March 9, 2005 Author Share Posted March 9, 2005 If it's a large diameter hose it probably goes to the "trombone" pipe at the top of the intermediate pipe (longer mid-pipe) just rear of your tranny. Its about 1/2 an inch or more in diameter, and maybe 6 inches or so is coming out of the body work. Will have a look for that trombone pipe and see if it goes there. My subu is carborated Thanks for all the help this board is great Please forgive my mechanical ignorance, I did take mechanics class back in high school but it was a long long time ago Quote Link to comment Share on other sites More sharing options...
Craven Posted March 9, 2005 Share Posted March 9, 2005 Do you have air conditioning? Quote Link to comment Share on other sites More sharing options...
moosens Posted March 9, 2005 Share Posted March 9, 2005 Right,that's the A/C condensation drain.....just let it hang. Quote Link to comment Share on other sites More sharing options...
Kraven Posted March 9, 2005 Author Share Posted March 9, 2005 Right,that's the A/C condensation drain.....just let it hang. Yup, do have air con Thanks Quote Link to comment Share on other sites More sharing options...
82GLF Posted March 10, 2005 Share Posted March 10, 2005 . Quote Link to comment Share on other sites More sharing options...
BlindSight Posted October 15, 2005 Share Posted October 15, 2005 am still looking for pictures of where the pipe is supposed to connect, cant seem to find my hot air stove, have looked and looked but dont see any possible place for it to connect to Quote Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted October 16, 2005 Share Posted October 16, 2005 If the heat shield is missing from the Y pipe ,, would there even be a place to connect the hot air duct???? Quote Link to comment Share on other sites More sharing options...
