bob88 Posted March 8, 2005 Share Posted March 8, 2005 HI, I am a new member and want to make my 98 a bit faster. Will the WRX motor fit in the engine bay? I knon I will need to upgrade a few things. Any tips will be appriciated Quote Link to comment Share on other sites More sharing options...
ballitch Posted March 8, 2005 Share Posted March 8, 2005 yes it will, go to ispeedusa.com and print out or look at there thingy they have for that conversion, oyu will need motor, entire car harness, engine harness, turbo legacy or wrx engine and tranny crossmembers, the up and down pipes form a wrx, would be good idea to get STI motor and tranny mounts, get the wrx 5 speed, unless you already have a manual tranny, if you have tranny, get it cyro'd, they submerged the tranny shafts in liquid nitrogen for 24 hours to super strengthen the outside of the metal, kinda like forging it, only with cold not heat. there are many other things that you will need but that is a start, try nasioc.com and sign up there. look in the aftermarket forced induction forum about how-to, and do some good olde' fashioned searching to get alot more details than i can give you right now. thats a start right. good luck. ~Josh~ Quote Link to comment Share on other sites More sharing options...
bob88 Posted March 8, 2005 Author Share Posted March 8, 2005 Thanks a bunch. But as I was talking to my close friend last night, I remembered that my car has the same engine as the 22B (EJ22). Wouldn't it just be cheaper to turbo the motor in it? Quote Link to comment Share on other sites More sharing options...
ballitch Posted March 9, 2005 Share Posted March 9, 2005 alot of people would like to turbo their N/A car, problem is the internals arent made for boosted applications, production turbo cars use forged internals, N/A some might but most dont, chepaer that way, but if you build the motor formt h ground up, you can put whatever you want in it, some people have turbo'd their stock N/A motors and have had no problems, some have had serious engine failure, i wouldnt, you might. the EJ22 in the 22B is closed deck design, the top of the cylinder bore near where the block and heads meet is solid metal, with oil and coolant passages of course, the N/A EJ22 in your car has no metal there, and the cylinder, under more boost than normal, flexes and you can breach your headgasket that way, no to mention warp your block and/or heads. now if you got a EJ22T block from an older turbo legacy or something you could build yourself a WRX killer, especially since you have the same suspension possibilities as the WRX, not to mention the lighter weight of your car, but lots of things car go wrong when you mix/match engines and cars, but isnt it so fun. ~Josh~ Quote Link to comment Share on other sites More sharing options...
bob88 Posted March 9, 2005 Author Share Posted March 9, 2005 Thanks a ton, dude. The info you have given me really gave me a boost. I have just one final question. Do you know any good sites where they sell subaru parts (engines, suspensions, ect...). The ispeedusa.com like doesn't work. Again thanks for the info. Quote Link to comment Share on other sites More sharing options...
ballitch Posted March 10, 2005 Share Posted March 10, 2005 try 1stsubaru.com and subaruparts.com they sell a litle aftermarket, but mostly OEM stuff on those sites. you can also try perrinperformance.com, cobbtunning.com those will get you started. have at it man. ~Josh~ Quote Link to comment Share on other sites More sharing options...
bob88 Posted March 11, 2005 Author Share Posted March 11, 2005 Thanks a bunch dude. Yoy es the man. You have really helped me get started. Thanks some more. Quote Link to comment Share on other sites More sharing options...
Dazed Dreamer Posted March 24, 2005 Share Posted March 24, 2005 I remembered that my car has the same engine as the 22B (EJ22). Wouldn't it just be cheaper to turbo the motor in it? not to be picky but the 22B has a EJ20 bored out to 2.2L Quote Link to comment Share on other sites More sharing options...
Ratty2Austin Posted March 25, 2005 Share Posted March 25, 2005 also try looking on http://www.nasioc.com , which is specifically an impreza board! the conversion is a lot of work but its do-able... best thing to do if find a wrecked car with the internals you want, that way all your engine and electronic parts will match up and you will also have most of the parts needed.. finding a impreza wrx parts car rather than a legacy turbo would help too, all the parts will fit better seeming as how you have an impreza... Quote Link to comment Share on other sites More sharing options...
