Decker_Forester Posted March 15, 2005 Share Posted March 15, 2005 The Subaru R160 LSD differential is this the right LSD for my 99 forester s auto???? Ben Quote Link to comment Share on other sites More sharing options...
GLCraig Posted March 15, 2005 Share Posted March 15, 2005 nope that one has the 3.70 grear ratio and you're forester needs a 4.444 gear ratio. Quote Link to comment Share on other sites More sharing options...
mudrat79 Posted March 15, 2005 Share Posted March 15, 2005 You can however convert it to work with your 4:444 gears in the rear diff though..... Do a search for LSD conversions in the Archives..... Quote Link to comment Share on other sites More sharing options...
thermalsurfing1 Posted February 25, 2009 Share Posted February 25, 2009 will it work in a 83 gl wagon ? Quote Link to comment Share on other sites More sharing options...
baccaruda Posted February 25, 2009 Share Posted February 25, 2009 an 83 GL wagon has a 3.9 ratio. The 3.9 gear can be put on that LSD to make it a 3.9. To make it a 4.11 or 4.44, the center section has to be modified to accept the larger bolts that the 4.11 and 4.44 gear require. Quote Link to comment Share on other sites More sharing options...
thermalsurfing1 Posted February 25, 2009 Share Posted February 25, 2009 this is what i found for sale Subaru R160 rear differentials gear ratio 3.54 Both viscus LSD. so it will work in my 83 with some mods ? Quote Link to comment Share on other sites More sharing options...
Qman Posted February 25, 2009 Share Posted February 25, 2009 this is what i found for sale Subaru R160 rear differentials gear ratio 3.54 Both viscus LSD. so it will work in my 83 with some mods ?VLSD do not work well in offroaders. Do not lock under low speed applications. Quote Link to comment Share on other sites More sharing options...
monstaru Posted February 25, 2009 Share Posted February 25, 2009 thats funny,i just did this and did not have to modify anything.i thought we talked about this?gees........ i just put a 4.44 ring gear on the clutch pak LSD unit and did nothing to modify.ask if you want pics.cheers, brian an 83 GL wagon has a 3.9 ratio. The 3.9 gear can be put on that LSD to make it a 3.9. To make it a 4.11 or 4.44, the center section has to be modified to accept the larger bolts that the 4.11 and 4.44 gear require. Quote Link to comment Share on other sites More sharing options...
ezapar Posted February 25, 2009 Share Posted February 25, 2009 thats funny,i just did this and did not have to modify anything.i thought we talked about this?gees........ i just put a 4.44 ring gear on the clutch pak LSD unit and did nothing to modify.ask if you want pics.cheers, brian The VLSD chunk is a little more compact than the other. This old thread is proof the search button works. Awesome to see folks using it. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted February 25, 2009 Share Posted February 25, 2009 VLSD do not work well in offroaders. Do not lock under low speed applications. They work great from MOST offroading. I.E. Mud, snow, sand, gravel roads. The one place where they are not as good as a clutch pack is rock crawling. I spend more time in mud and snow than rock crawling and the VLSD works great for that. That is why the VLSD is used in the newest and best Subies. Quote Link to comment Share on other sites More sharing options...
