rpm vs. speed
I assume you dropped the 5-speed D/R in?
If so then you should be cranking about 2500 for 55, and just under 3k for 65 - 5th gear is a bit hard to approximate, the others are easier.
The cable is easy to get at on the tranny side (at least in EA82 cars) - fix it and forget it.
