starkiller Posted April 15, 2005 Share Posted April 15, 2005 ok, in case i do decide to keep these 15" pug alloys, what do i do for a spare? i would guess one wont fit underhood..am planning on running 205/60/15... Quote Link to comment Share on other sites More sharing options...
samo Posted April 16, 2005 Share Posted April 16, 2005 I use a same tire as the the 4 others (185/70/14 Yoko K2 F720), that way I can still run it in 4WD in an emergency situation. Nothing much bigger than stock will fit in the engine bay. Quote Link to comment Share on other sites More sharing options...
MorganM Posted April 18, 2005 Share Posted April 18, 2005 I'm a big fan of full size spare tires also; especially if you upgrade tire sizes. Get something that's the same diameter and width if possible. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted April 18, 2005 Share Posted April 18, 2005 You might be able to carry a full-size, same-size tire/wheel if you keep it deflated. A can of air or a portable compressor competes the setup. Quote Link to comment Share on other sites More sharing options...
GLCraig Posted April 18, 2005 Share Posted April 18, 2005 I'm pretty sure a 185/80/13 will fit the spare tire area and according to the Miata tire size calculator ( http://www.miata.net/garage/tirecalcold.html book mark this one) is the same diameter as a 205/60/15. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted April 18, 2005 Share Posted April 18, 2005 Ehhh I dont know if a 185/80 will fit... remember my white 88 wagon Craig? That thing sat at least an inch higher than my 87 with 185/70's though it may have been the struts too. Only one way to find out though... try cramming it in there. May have to be deflated though... I like that idea... keep it at like 10 PSI so you can air it up faster than just atmospheric pressure. Quote Link to comment Share on other sites More sharing options...
