ktperry Posted April 16, 2005 Share Posted April 16, 2005 I have a 1983 Brat with a EA81T and I was thinking of getting a Ea82T for it is it worth the work to convertit or just to rebuil the EA81T? Will I get a lot more power out of the EA82T? And how hard is it to convert it. Is the wire really hard? Thanks Quote Link to comment Share on other sites More sharing options...
Ross Posted April 16, 2005 Share Posted April 16, 2005 Wiring would be a farily large task: you would need the entire ea82t loom including the one under the dash. The ea81t should put out a fair amount of power if some mods are done - i'm in the middle of rebuilding one myself. Depends on how much is wrong with your ea81t though. If block, and especially heads are ok, then i think you should rebuild it. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted April 17, 2005 Share Posted April 17, 2005 My vote as an EA81T owner is to keep it original! Quote Link to comment Share on other sites More sharing options...
royboy159 Posted April 17, 2005 Share Posted April 17, 2005 I have a 1983 Brat with a EA81T and I was thinking of getting a Ea82T for it is it worth the work to convertit or just to rebuil the EA81T? Will I get a lot more power out of the EA82T? And how hard is it to convert it. Is the wire really hard? Thanks Hey kt----Are you swithching out the EA81t because the original problem it had was never cured? If so, that's a shame. We should fix it first. Quote Link to comment Share on other sites More sharing options...
