Jwats612 Posted September 4, 2003 Share Posted September 4, 2003 I just switched my 99 Legacy to Mobil One 5w-30 which works fine so far. Two questions: 1. How long a change interval do you think is safe--car is driven mostly on highway with no stop and go. 2. Does anyone have experience or advice on the 0-40W weight for winter use? While car is garaged, Cold is extreme in Minnesota thanks John Quote Link to comment Share on other sites More sharing options...
jsavrtka Posted September 4, 2003 Share Posted September 4, 2003 Hi John, I use Mobil-1 15W-50 year round. And up here, it also gets chilly.:bday: I still change it every 5000 km or so. Aren't synthetics great! jim Quote Link to comment Share on other sites More sharing options...
99obw Posted September 4, 2003 Share Posted September 4, 2003 I have used both Mobil 1 and Amsoil. I use 5w-30 in the winter and 10w-30 in the summer. I live in a Zone 4, so it gets pretty cold. I personally won't go thinner than 5w-30. With Mobil 1 I was changing the oil every 3-4k miles. Now with Amsoil I am changing the oil about every 3 months, or about every 7500 miles. I could go longer, but I think doing so would require oil analysis, and that is almost as much as changing the oil. The engine seems much happier with the Amsoil. The engine is quieter at startup. I can run it for 3 or 4 thousand miles before the color darkens noticably. Regardless of what oil you choose, use a quality oil filter. I really like the Amsoil filters, but I think I should find something cheaper, they are about $11 each. 15w-50 year round! Wow! Quote Link to comment Share on other sites More sharing options...
jsavrtka Posted September 4, 2003 Share Posted September 4, 2003 I don't have a clue what you're talking about with the zone 4--luckily google does. So, I guess I live in a zone 3a climate. Anyway, the pour temp on 15W-50 (-45 C) is still lower than dino-based 0W. I prefer to have a little viscosity to my oil. Mobil-1 10W-30 always seemed to have the consistancy of water while draining it. Any oil with 'energy conserving' on it I don't touch. [paranoia mode off] I've never had sluggish cranking while running 15W-50 and I don't even have a block heater in my sub. YMMV jim Quote Link to comment Share on other sites More sharing options...
Setright Posted September 4, 2003 Share Posted September 4, 2003 Mobil 1, all the rest are second best :-) 5w-50 in Danish Spring/summer, temps up to +33 celcius 0w-40 in winter, where the temp regularly goes below freezing. There is a tiny, but noticeable difference in start up: 5w sounds a bit strained on frosty mornings. As soon as I swap to 0w she starts as if it were a warm summer day! 6000 mile intervals, which equates to every three months. Car is nearing the 200,000 milestone Also have Mobil's finest in the manual transmission Quote Link to comment Share on other sites More sharing options...
Snowman Posted September 4, 2003 Share Posted September 4, 2003 I'm running Mobil 1 10W-30 right now, and I change it every 3-4,000 miles. Yes, you CAN run it longer than that, but it doesn't matter how good your oil is, it still gets contaminents in it after a while, and the more often it's changed, the less those contaminents are wreaking havoc on your engine internals. Quote Link to comment Share on other sites More sharing options...
edrach Posted September 5, 2003 Share Posted September 5, 2003 I'm thinking about going that route and would probably prefer the Amsoil. However, what have you guys got against the OEM oil filters from Subaru? Quote Link to comment Share on other sites More sharing options...
Setright Posted September 5, 2003 Share Posted September 5, 2003 I use the OE oil filter, and I would NEVER go for a cheap copy. There is a big difference in the filtering properties of the paper element, not to mention the total surface area. Also, the bypass valve can be relied upon to not open unless the filter really is clogged. I don't doubt that there are even better quality filters out there, Amsoil included, but replacing an OE filter every three months is costly enough I am sure Mobil 1 can last 6000 miles under the conditions that I subject it to, don't forget it's only in there for three months, and it's only cold-started once a day since I am on the move all day. I am however VERY sceptical of so called modern car's extended service intervals. Honestly, running the same oil for 20,000 miles?? Quote Link to comment Share on other sites More sharing options...
99obw Posted September 5, 2003 Share Posted September 5, 2003 I would never run Amsoil for 25k miles as they suggest. To do so safely requires periodic oil analysis, and many engines won't make it that far before the oil requires replacement. I feel pretty comfortable with 7500 miles intervals. I am totally sold on synthetic. When I had the engine apart for head gaskets it was clean as a whistle with very little wear. I was running Mobil 1 at that point. Quote Link to comment Share on other sites More sharing options...
incognito Posted September 6, 2003 Share Posted September 6, 2003 Ugh... people really need to learn what oil does for a car. Some people are far more dumb than they need to be when it comes to oil. :madder: Quote Link to comment Share on other sites More sharing options...
incognito Posted September 6, 2003 Share Posted September 6, 2003 Just so you know. 4.25 quarts. 17mm drain plug wrench (EJ251) (K&N) HP 1004 oil filter (for EJ251) (up to you) 2,500 Miles or 3 months. (1,000 miles for me ) 10W-30 Summer 5W-30 Winter. Just dont use pennzoil with their wax based oil. Mobil 1 is a great synthetic, when compared to castrol synthetic oil. Oh, and that lil MMO (marvel mystery oil) experiment is a crock of crap, the difference people are feeling is only their oil being changed. Yes, your car will feel alot better after an oil change. I miss anything??? Quote Link to comment Share on other sites More sharing options...
ibis315 Posted September 10, 2003 Share Posted September 10, 2003 Check this out : http://neptune.spacebears.com/cars/stories/oil-life.html Quote Link to comment Share on other sites More sharing options...
sprintman Posted September 11, 2003 Share Posted September 11, 2003 BITOG forum and FAQ's etc will teach you all you want to know about oil, filters both air & oil, greases. additives, engine internal cleaners, fuel system cleaners and much more such as which oil filters have the least pressure drop etc. No flaming and many contributing STLE"s, other highly qualified tribology experts and even Blackstone Analysis and Terry Dyson Analysis are contributors. Sure helped me get my Outback running far better and much better economy too. Also you will learn why Pennzoils new Purebase is generally regarded as one of the top three dino's in the industry (it's a Group II+ basestock) along with Delo 400 and Mobil Delvac 1300 Super. One of the main reasons Shell bought Pennzoil/Quaker State. Wax based it certainly isn't (it's parafinic) as are Conoco, Chevron, Havoline etc Group II+ basestock products but it's far too complicated to explain here, and requires somebody far more knowledgeable than I to do so correctly. http://WWW.BOBISTHEOILGUY.COM for more Quote Link to comment Share on other sites More sharing options...
Commuter Posted September 11, 2003 Share Posted September 11, 2003 Welcome back spagemurry... :-) Quote Link to comment Share on other sites More sharing options...
sprintman Posted September 11, 2003 Share Posted September 11, 2003 Hello Toronto. Hope to get there one day, and catchup with some bitog folks 'in the flesh'. This forum is excelent fot those lucky enough to drive a Subaru IMO. Quote Link to comment Share on other sites More sharing options...
tcspeer Posted September 11, 2003 Share Posted September 11, 2003 Battle Wagon Medic, easy on pennzoil my 97 Legacy has 262,000 miles and has seen nothing but pennzoil. nearly all of the major oil's I think exceeds manufacturers warranty, I would not have doubts about using most of them. Quote Link to comment Share on other sites More sharing options...
sprintman Posted September 11, 2003 Share Posted September 11, 2003 Exactly. Till I found BITOG I wouldn't have touched Pennzoil even though it's everywhere here in Aussie just because of all the old wives tales. The new Pennzoil Quaker State base oil refinery was a joint efort with ConocoPhilips called Excel Paralubes that gave rise to the Purebase range, a whole new ball game. Conoco Hydroclear same stuff I believe. As part of Shells takeover of PQS a condition was that it's 50% share of Excel Paralubes had to be sold and Flint Hills Resources LP are the purchaser. Purebase is a Group II+ basestock, excellent additive package and now a healthy dose of moly. Hard to beat and excellent value for money. I currently use 5W30 version in my OB doing an after Auto-Rx rinse. FWIW It's the last time I will use an XW30 in any vehicle I own, the OB sounds like a tin can full of ball bearings, so back to XW40 soon. Quote Link to comment Share on other sites More sharing options...
Setright Posted September 11, 2003 Share Posted September 11, 2003 BattleWagon, you did miss something: When I replace my oil at 6K miles, I cannot feel any difference in performance. If I laze about and leave til 7k miles there is a noticeable new urge after the oil change. I reckon 6k miles is just right for me Quote Link to comment Share on other sites More sharing options...
sprintman Posted September 11, 2003 Share Posted September 11, 2003 Which oil and viscosity? Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted September 12, 2003 Share Posted September 12, 2003 Mobil 1 10W30 for 7,500 miles, new filter and top off every 2,500. Quote Link to comment Share on other sites More sharing options...
sprintman Posted September 12, 2003 Share Posted September 12, 2003 New filter every 2500 is good. Also M1 Supersyn is a vastly superior oil to M1 Trisyn (it needed to be). M1 has about 80ppm moly in the blend now, about time IMO. Quote Link to comment Share on other sites More sharing options...
CROSSTBOLT Posted September 12, 2003 Share Posted September 12, 2003 Battle-wagon-medic, why the slam on Penzoil? I have heard all kinds of bad stuff from all sorts of folks about Penz and never had anything at all bad happen. I have been using the stuff since '62. The truth is I could have used any brand just so I used something REGULARLY. Quote Link to comment Share on other sites More sharing options...
Setright Posted September 12, 2003 Share Posted September 12, 2003 Sprintman: Why so hard on M1? The "original" from the late eighties kicked some serious behind. I can't believe they would have made an inferior product?? Except maybe if they decided to exploit a reputation and make some extra money for themselves. :madder: I still run M1.. Quote Link to comment Share on other sites More sharing options...
sprintman Posted September 13, 2003 Share Posted September 13, 2003 Trisyn was somewhat lacking in barrier lubrication. Supersyn UOA's are so much better across the board. Now contains moly which is good. About the best OTC syn around these days. You really can't go wrong with the current M1 but they are formulated at the low end of the 30W range which causes consumption problems in many vehicles. Why Mobil don't have a 5W40 M1 I dont understand. Many Sube owners use Delvac 1 (5W40) which as a fleet oil is CI-4 and SL rated. A very shear stable product. Quote Link to comment Share on other sites More sharing options...
Setright Posted September 13, 2003 Share Posted September 13, 2003 Don't you hate regional variations? The M1 I used to use in Singapore and still use in Denmark is 5w-50..... As mentioned, 0w40 in winter - "tri-syn" Quote Link to comment Share on other sites More sharing options...
