bustle Posted April 26, 2005 Share Posted April 26, 2005 All right Subu-Guru's. How does the rear window washer thing work? I have a switch on the dash that activates rear wiper. I got a squirter thingy on the rear door. I looked in one of those rear compartments and find a hose that went up into the door but ended in the little compartment. How is this thing routed? Does it T into the front ones or is it supposed to have it's own stuff. The 3 repair manuals I have make no reference to it that I can find. Also, is there an aftermarket trick to get replacement hatch lifts? Or are we stuck with Factory replacements? Mine are O.K. for now but apparently don't work in winter. Is there a quota on stupid newby questions? Thanks all. Quote Link to comment Share on other sites More sharing options...
Buddy Posted April 26, 2005 Share Posted April 26, 2005 yo wussup man! all i can tell you is that if its an EA82 wagon you'll find all the hardware in the area were the jack is. in other words its on the left side of the the cargo area. all you gotta do is take out your jack without damaging all the hardware that's in there if you have any more questions on that go ahead and PM me and i'll give you more info. P.S. just to be sure is it an ea82 wagon? (1985 and newer) because i only know about that year and later. Quote Link to comment Share on other sites More sharing options...
Bill90Loyale Posted April 26, 2005 Share Posted April 26, 2005 Press on top of toggle switch to activate wiper. Press on bottom to activate washer. Washer fluid container is in left rear (as you look at car from rear) lightbulb hatch. Pump etc. underneath as described above. Quote Link to comment Share on other sites More sharing options...
bustle Posted April 26, 2005 Author Share Posted April 26, 2005 Yes an E82 Wagon. Went in there this morning and low and be blowed if someone hasn't done a pumpectomy. I found the wire plug and hose but everything else is missing. Quote Link to comment Share on other sites More sharing options...
MorganM Posted April 26, 2005 Share Posted April 26, 2005 Sounds like a previouse owner removed it; most likely due to it being broken. Junkyard should have what you need. Quote Link to comment Share on other sites More sharing options...
