simbey1982 Posted April 26, 2005 Share Posted April 26, 2005 Will Rear STI struts fit on my GC8 Body impreza?? 1997 4 door if you want to know...thanks Quote Link to comment Share on other sites More sharing options...
simbey1982 Posted April 26, 2005 Author Share Posted April 26, 2005 bump it up Quote Link to comment Share on other sites More sharing options...
jamal Posted April 26, 2005 Share Posted April 26, 2005 The tops don't match up. You can use GC tops and spring perches or file out the holes on the strut towers. Quote Link to comment Share on other sites More sharing options...
subyrally Posted April 26, 2005 Share Posted April 26, 2005 it WILL lift your car about 1.5-2". i put in 2004 wrx suspension all the way around my car and got lifted but stiffer suspension. i reccomend looking into like ver5 sti parts that will fit right, either that or keeping your stuts and using the newer springs. with the springs from the newer cars, you will get a much stiffer ride than stock due to the fact that the newer body styles weigh in about 400 pounds more than the gc style cars. Quote Link to comment Share on other sites More sharing options...
simbey1982 Posted April 27, 2005 Author Share Posted April 27, 2005 here is the link if you can tell me more.... http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=7969646832&sspagename=STRK%3AMEWA%3AIT Quote Link to comment Share on other sites More sharing options...
jamal Posted April 27, 2005 Share Posted April 27, 2005 I would really not recommend you just buy a set of rear struts. They won't match your springs, and you will have different struts front and back. Your car will not handle well at all. Find a whole set of take-offs if you want to put in STi struts (also they'd have to be from an 04). Also, just putting in the struts won't raise your car. The reason they're lifted is because the GD is heavier, as was mentioned. The springs are what would cause your car to sit higher, as they aren't compressed as far. Quote Link to comment Share on other sites More sharing options...
subyrally Posted April 27, 2005 Share Posted April 27, 2005 its not that its heavier, granted that does make a difference, its that the struts mount about an inch and a half higher in the body of the newer imprezas. i compared both sets of struts side by side and the newer units were noticable longer. I would really not recommend you just buy a set of rear struts. They won't match your springs, and you will have different struts front and back. Your car will not handle well at all. Find a whole set of take-offs if you want to put in STi struts (also they'd have to be from an 04). Also, just putting in the struts won't raise your car. The reason they're lifted is because the GD is heavier, as was mentioned. The springs are what would cause your car to sit higher, as they aren't compressed as far. Quote Link to comment Share on other sites More sharing options...
simbey1982 Posted April 27, 2005 Author Share Posted April 27, 2005 alright...point taken...thanks guys i appreciate the help Quote Link to comment Share on other sites More sharing options...
