The Truth about RX Turbo Fuel Injector Flow Rates
hmm maybe i will try myx's flowed injector rating on my rx's fuel table and see how well it likes it ..
i have mine set for 80 cc a min on my megasquirt setup and it seems to run pretty good for a tired old motor
edit: my one key is borked .. so make that one eighty cc's
  • 4 weeks later...
btw according to a fuel psi conversion utiliity for one of my megasquirt tuneing programs
240 cc/min at 43psi converts to
219 cc/min at 36 stock suby psi
now i assume the 36 psi we are supposed to get is only at idle ect
or is that the max full boost fuel psi the regulator provides? since that might be useful to know
Clayton, the Fuel Pressure regulator doesn't regulate at a straight 36 psi.
The regulator is setup to deliver a steady 36(point something) PSI above manifold pressure.
ergo, at 10 psi of boost, you should be seeing 46psi at the injectors
Guest shadow
The Subaru regulators should be 36psi at atmospheric. Under vacuum the pressure should drop, and conversely rise under boost. I still have my megasquirt set to 185, although 219 would be the proper number given the test results as Clayton said. A regulator from a 42psi car would be an upgrade in addition to fuel management, giving you the maximum from the stock injectors.
thats kinda what i wanted to know is the when and where the max psi occured at
  • 1 month later...
So I got my RX injectors back from RC engineering. The results were good. Interesting to look at the before and after picture
you can see the cleaned on the right. The gap is wider, and they all came back a different color? wierd
off my donor engine never actually ran in my rx:
before/ after
221--Dripping/ 238 exc
230--good /240-exc
235--good /242-exc
1 with electrical damage
replaced with injector from car
220--good /240-exc
Interesting how the one that was actually on my car, had a good spray pattern but, the worst cc/min
  • Like 1
