Towing a 79 4WD with a tow bar
I'm considering towing a 79 4WD wagon 900 miles with an adjustable tow bar. Has anyone tried this? What experience has anyone had? any suggestions regarding whether or not to disconnect the shafts all around? just the front? Thanks, Cricket
the old ones with manual trannies like that can be flat towed without removing any shafts. just make sure you are in 2WD and Nuetral. and make sure the steering wheel isn't locked.
lots of soobies were flat towed behind motor homes in the 70's/80's.
To repeat what everyone else said.. leave it in FWD, shifter in neutral and ride. Keep up with those tires though, and make sure the steering is unlocked.
BTW, its a 5 speed? I remembered reading that the EA71s came with 4 speeds. Am I wrong?
Well, now I don't remember if it's 5 or 4 speed. I'm looking at a tow bar that supposedly attaches right to the bumper bolts and doesn't need a "bracket." Which is why I was asking about it.
i towed a sedan from fort wayne indiana to hillsdale michigan with my ea82 sedan, in the snow, 4wd and 45 mph. did ok
towed a wagon to the junk 20 miles 55-60 mph no problem
future plans involve towing a wagon across iowa 400 miles, with the ea82 sedan, 5spd dual range no driveshaft lo when needed
the tow bar i have was modified to fit any ea82 body in a non permanent fashion, to tow with an ea82 or ea81 with a hitch. or anything with a hitch for that matter
  • 3 weeks later...
just make sure its in neutral... a guy towed a sami behind a motor home while the car was in 1st... went up to like 20000rpm... not good...as long as its not an automatic you can tow it as far as you want...
Just remember ....
You can NOT back up while the car is connected to the
tow vehicle.
some lessons in life are learned the granite way
Not even if the tow'd vehicle is running?As in idling in neutral.
" Not even if the tow'd vehicle is running?As in idling in neutral."
If this comment was directed at my statement??
Please be advised, the comment I made has nothing to do
with the drivetrain of the tower vehicle.
But is directed at the fact that....
The front wheels will cock and jack the knife
will occur within meters.
as I said - the the path to knowledge is sometimes strewn with
Gibraltars
Gibraltars
It was a question,not a comment.
Gibraltars
How about if someone gets out and helps keep the wheels from cocking? :brow:
P.S. Flat Towed an 84 brat from San Diego to Tucson behind a 1-ton F250 Turbo Diesel.
If the person in the towed vehicle tries to correct ...
the towed vehicle will try to streer the towing vehicle via
the tow hitch
This is not good in some situations.
P.S.
Update. See thread about towing disaster (which had nothing to do with the tow bar setup): http://www.ultimatesubaru.org/forum/showthread.php?t=37058Anyhow, I drilled four 1/2" holes (2 per mounting bracket) right through the front of the bumber, as close as possible to the bumber's brackets. Then I attached the tow bar brackets at the holes. Hooked everything up and it worked just fine. I even went up a pretty steep incline in Colorado Springs just before the mishap described in the other thread. My biggest concern was whether or not the tow bar bracket bolts would come right through the bumper metal under pressure. The bolts/brackets held up just fine.
Thanks for all the help about towing. I'll be back in Colorado Springs next weekend to bring the wagon. Again.
