Gravityman Posted May 21, 2005 Share Posted May 21, 2005 Should I pick up a Rising Rate Fuel Pressure Regulator for $90 bucks for my ER27 Twin Turbo setup? Good Price? new Quote Link to comment Share on other sites More sharing options...
archemitis Posted May 21, 2005 Share Posted May 21, 2005 only if your gonna do it up ghetto style. ever thought of a haltech, or megawhatever? Quote Link to comment Share on other sites More sharing options...
Gravityman Posted May 21, 2005 Author Share Posted May 21, 2005 I am still thinking about the megasquirt system haltech is a little too much for my taste. But along with that I would imagine that a rrfpr will still be a good addition to the mix. Quote Link to comment Share on other sites More sharing options...
operose Posted May 21, 2005 Share Posted May 21, 2005 megasquirt all the way! I plan on converting my regular old er27 to use megasquirt/spark, simply for tunability Quote Link to comment Share on other sites More sharing options...
archemitis Posted May 21, 2005 Share Posted May 21, 2005 you wont need a rising rate regulator, if you build your system for boost. you will use a 3 bar map sensor(most likely) so you dont have to trick your computer into giving the motor the fuel it needs. it will know its getting boosted, and give more fuel accordingly, by adjusting pulse width, not the fuel pressure. with megasquirt you wont need it. if you stay with stock computer, buy it, cuz you'll NEED it =] Quote Link to comment Share on other sites More sharing options...
torxxx Posted May 22, 2005 Share Posted May 22, 2005 wow... what a project.. I want to see pictures as you go along building it up Quote Link to comment Share on other sites More sharing options...
ThreeEyedBandit Posted May 22, 2005 Share Posted May 22, 2005 I would second the megasquirt also, way more tunable and if a problem arrises then 'you' can solve it. Matt Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted May 28, 2005 Share Posted May 28, 2005 If you could get a fuel controller, use it. You could control your fuel injectors at a specific rpm. So if you fuel pressure is a little to high for low end boost, you can taper back how far your fuel injectors flow with the fuel controller. I have been unsuccessful trying to get two different fuel controllers to work (Hyper fuel SFC and Apexi SAFC). If you could get the Apexi SAFC to work, that would be great. I had trouble setting the correct Sensor Calc and Sensor Number settings. No-one could help me, including Apexi USA and Japan. Only do these things if you get a higher flowing fuel pump and fuel injectors that are not more than 277cc. I pick 277cc because it is up to 50% higher than the stock 185cc XT6 fuel injector. Beyond that would be outside the realm of your fuel controller. Quote Link to comment Share on other sites More sharing options...
Gravityman Posted May 28, 2005 Author Share Posted May 28, 2005 I have been reading up on the MS and I am looking in to the megasquirt/jolt edis, Has anyone added edis to their XT6 succesfully? As far as the stock fuel injection setup what is the problem with the fuel mapping? I heard that at some point in the RPM range the injectors flow constantly open. I already know the injectors are inadiquate. Some insight please? Is the biggest problem going lean at high revs? Quote Link to comment Share on other sites More sharing options...
