bajavwnsoobnut Posted July 24, 2005 Share Posted July 24, 2005 Hey just out of curiosity what are the differences in length and width between the regular 5sp d/r 4wd tranny and the 5sp full time 4wd w/ center diff lock (non RX) trannies are? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 24, 2005 Share Posted July 24, 2005 external dimensions are the same, aside from the diaphragm sticking out of the full time for that matter the full time is the same as pushbutton with the diaphragm (overall dimensions) Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted July 24, 2005 Author Share Posted July 24, 2005 ok just was curious cause of thinking of what about the center diff and where it's located and if it's the same lenght as the d/r or is it as long as the 3AT Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 24, 2005 Share Posted July 24, 2005 they mount the same using the same driveshaft and crossmember, clutch and all. like legos man, you knew that. LEGOS. is it the same size, does it fit? just remember the lego man! Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted July 25, 2005 Author Share Posted July 25, 2005 well the purpose I have and idea for using it for won't be as simple as legos Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 25, 2005 Share Posted July 25, 2005 its just more legos, from a different kit. who says you cant mix lego and mega bloks? Quote Link to comment Share on other sites More sharing options...
