86subaru Posted July 24, 2005 Share Posted July 24, 2005 cleaned the IAC and now car will not stay running ? it is a 88 spfi 5sp d/r wagon,all vacuum lines hooked up ,all wires pluged in , it runs good as long as you hold the gas pedal down Quote Link to comment Share on other sites More sharing options...
86subaru Posted July 24, 2005 Author Share Posted July 24, 2005 bump:banghead: Quote Link to comment Share on other sites More sharing options...
86subaru Posted July 24, 2005 Author Share Posted July 24, 2005 this i what i did , the problem may have been is i used another one ,that looked good and cleaned it good , put it on and no go , sooooo i cleaned the old one and put it back on , still idles like before , but aleast i can drive it :-\the other iac was from a same year car ? either it is bad or something else Quote Link to comment Share on other sites More sharing options...
tizzle Posted July 25, 2005 Share Posted July 25, 2005 I had to replace the gasket on mine too. Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 25, 2005 Share Posted July 25, 2005 Have you checked the intake manifold gaskets for a leak? They could be leaking coolant, air, or both, into the intake. Quote Link to comment Share on other sites More sharing options...
86subaru Posted July 25, 2005 Author Share Posted July 25, 2005 no coolant leak etc.. , seems the other iac was bad , but still back to the same problem as before i started Quote Link to comment Share on other sites More sharing options...
ShawnW Posted July 26, 2005 Share Posted July 26, 2005 Is it the wrong kind of IAC? I think you need a 3rd one and are on the right track. Quote Link to comment Share on other sites More sharing options...
