High Miles on your Legacy Outback?
I have known a whole lot of Subie owners with 2.2s and smaller who did minimal maintence and just cured the oil leaks with another quart of oil.
Treated like this these cars have been wonderful.
The 2.5s have been another story.
The good part is the way the new 2.5 head gasket fails is that if you keep water in the car, and just sort of expect that it goes down now and then, the car will run fine.
The owner I bought my car from had no idea the head gasket was weeping, and I would not have known to look if I had not read it here on the board.
I suspect there are a bunch of phase twos running around that just seem to lose a little water.
Like you I would love to know the real percentage of cars that have problems like this, but it would require some sophisticated surveys.
You could probably make an educated guess if you were to contact all the engine rebuilders that do subies in a city like Seattle, and take that number by the amount of subies registered in that city.
This would give you a percentage anyway.
well my 93 2.2 has 230,000, with no engine problems and 10 Buffalo, NY salty winters. All this head gasket talk has me thinking NO OUTBACK or 2.5 when it comes time for a replacement. What a bummer, for someone who has always had 200,000+ mile engine trouble-free subarus, this sounds as bad as owning a ford or chrysler. What is the real scoop? Should I only look at used 2.2 legacies (up to what year?) Outbacks, seem definately out of the question if the darn thing is gonna need that kind of work by 200,000. Spoiled, you bet....
What years are the Phase 1 engines and the Phase 2 engines? What are the major differences between the two? The reason I'm asking is because I'm about to buy an OBW but I'm wondering if I should be getting the newer style (2000 and up) vs. the older style (currently looking at a 98 and 98).
Thanks,
Matt
Originally posted by 99obw
Well, with the Phase I 2.5 is does seem to border on routine maintainence. My guess is that a huge percentage of these engines will eventually have head gasket failure, it's just a matter of when. I feel pretty confident that my repair with the newest gasket revision should last the life of the car. If not, it's a pleasure to work on, and I would gladly replace it again.
I must add that despite the troubles I have had with the car, it is extremely well designed and built. By far the best car I have owned, and I have had ford, dodge, chevy, cadillac, buick, nissan, and toyota. I am not saying subarus are the best cars in the world because I haven't owned every make, but they are IMHO the best car I can afford.
At 90k miles I had the dealer change timing belt and perform the maintenance schedule. Then at 94,000 miles the head gasket failed. I always have wondered if there was a connection. Other than the head gasket my '98 Outback is great. But the timing belt and other service was $1100 and the head gasket was $2500. I always had regularly scheduled maintenance performed by the dealer also. So it probably cost over $4000 to get past the 100k mile mark. Right now I have 103k miles and it drives like a champ.
In august I test drove a legacy LE and a Forester. They were both '03's with automatic and the legacy seemed a lot slower 0-30 and still seemed slower than my '98 throughout the range to 70mph. The Forester was better, probably because it is lighter?
At 96,000Kms I had the "Big" service done on my 2000 Legacy, It included a bunch of things and cost me over $1K CDN.
One of the things included was to replace / flush the coolant.
Immediately after I noticed an odour, which turned out to be an external head gasket leak.
I was wondering if there was a connection????
The Leg SE has a 3.90 rear end which causes it to be slow.
The Phase 2 is no better
Good question, as I noted earlier I own two '97 Outbacks with 87K and 118K, no problems, and six other friends own '97 or '98's. One has 146K. None have had head gasket problems. So we're all really lucky or the problem isn't as widespread as the sample of users here would make it appear. The fact that these crs receive high reliability ratings from everyone makes me think it is the latter. No consolation if you have had the problem, though.
I hope you are right in that hd gaskets are not a wide spread problem and just a few of us making noise. Subaru of America agrees with you. Although, when I picked up my new headgasketed '98 Outback at the dealer. the Service Manager said there were now 3 more sitting in the lot waiting for new headgaskets. He also said it wasn't a big deal. He had worked at the Toyota and Honda dealerships and they also had head gaskets go bad. He said at least I didn't need a new tranny or engine.
  • 9 years later...
Wrecked my '96 with the infamous EEE JAY TWENTY-TWO at 250,000 miles. Never replaced a wheel bearing, or head gasket, or water pump, or oil pump, nothing major. Timing belt, hoses, a/c belt, oil changes, brake pads and diff/trans fluid. Car was ROCK solid, and the engine now resides in my sisters '96 Legacy that had a bad valve because she drove it on a miss too long (my fault, I told her it was fine to drive on a miss. I think the miss was a bad injector, but not sure). It is now pushing 280,000 and doesn't even burn oil.
259k, 93 legacy wagon.  Haven't had to do anything too major, clutch, cv boots, ball joints, tie-rod ends, some wheel bearings, etc.   Right now I need to change the timing belt and replace a bunch of blown out bushings (mostly my fault for driving on a blown strut or bad ball joint and just driving like a madman on dirt roads) and she should be ready for another 100k.  The body is pretty rough these days but she runs strong and takes me to amazing places.
Edited by 14D
Got a '96 from General Disorder early 2012, had over 200K.  Got about 238K now.  Has been an excellent car.  Smokes a little after long downhill coasts from Tahoe, but Just about every other Sube of that era does that.  Completely satisfied.
Just my 2 bucks
Edited by NV Zeno
Good topic learned a lot but what i want to know is that anyone have a oil leak around the spark plugs? Please let me know what you did to stop it and post it please. gunner.
You may want to start a new thread on this and include Year Model and engine size.
Getting read to roll 225k in my 96. On its third transmission due to mainshaft bearing failures. Pulled the engine and did a complete reseal at 190k to fix all of the oil leaks (did the head gaskets too, even though it didn't need them at the time).
One wheel bearing replaced, have another on the way out. Did rear struts around 170k because the rear springs were worn out and sagging.
I just hit 265K this week, got my emissions done today which I passed car idles smoothly just gotta take care of the rust on the passenger side rear area.
Noticed the car is starting to get a little bouncy now.. it's going to suck getting struts again.. I might put STi struts on... lost 4 brand new KYB struts in my last legacy that i totaled.. they had to only be like 4 months old.
Edited by 1-3-2-4
