Guest subu luvr Posted September 19, 2003 Share Posted September 19, 2003 sitting at stoplight, idling smooth, occationally it revs up 200 rpm then drops back to where it was in a 3-5 second cycle any ideas? going out to pull the codes now Quote Link to comment Share on other sites More sharing options...
Scrub2k Posted September 19, 2003 Share Posted September 19, 2003 Sounds like you have a vaccum leak to me, i'd check all of your vaccum lines, my honda did the exact same thing when i had a cracked vaccum line. -Matt- Quote Link to comment Share on other sites More sharing options...
c150L Posted September 19, 2003 Share Posted September 19, 2003 Might want to check the putor codes if you get bored. I thought someone once said that a bad connection on the the engine coolant temp sending unit can raise havoc. Could the air conditioning have anything to do with it? Don't think it was a Sube, but I remember a car that the idle would spike up just a bit before the AC compressor would kick in. Then the putor would again calculate out the correct idle speed. Just guessing for you. Quote Link to comment Share on other sites More sharing options...
c150L Posted September 19, 2003 Share Posted September 19, 2003 Careful with those vacuum lines and plastic fittings. You remember! LOL Quote Link to comment Share on other sites More sharing options...
archemitis Posted September 19, 2003 Share Posted September 19, 2003 that thing always did that, even with the other motor. i think its the idle air controll valve sticking. b12 chemtool helps it go away for a while Quote Link to comment Share on other sites More sharing options...
Guest subu luvr Posted September 19, 2003 Share Posted September 19, 2003 thankie, i will try that Quote Link to comment Share on other sites More sharing options...
