dan360 Posted September 16, 2005 Share Posted September 16, 2005 Hello everyone, I recently got my hands on an 84 GLwagon with 206k miles on it. The only thing that wasn't working were the turn signals. I found the hazard knob in the "on" position and when i turned it off they worked. Prior to finding that i checked all the fuses. The fuse labeled horn/hazard/clock was blown. I installed a new one and it blew on contact with the key not even in the ignition. The clock works although it's always 1:00 no matter what time i get in. I'm not even concerned about it. The horn and hazards do not work. I know certain leads are hot all the time but that doesn't explain it blowing the 15 amp fuse that it's rated for. I suspect the turn signal / hazard unit buried in the dash is bad. If anyone knows of something else it could be i'd really appreciate the info. Quote Link to comment Share on other sites More sharing options...
Snowman Posted September 16, 2005 Share Posted September 16, 2005 More likely the wiring going to the switch or flasher unit. Does the fuse blow with the turn signals off or on? Quote Link to comment Share on other sites More sharing options...
Snowman Posted September 16, 2005 Share Posted September 16, 2005 Oh, I'm very observant...my question was answered in your post. It's probably a shorted wire. Quote Link to comment Share on other sites More sharing options...
dan360 Posted September 16, 2005 Author Share Posted September 16, 2005 Thanks for the info, tommorow i'll check all the wiring from the switch on the column to the unit. Quote Link to comment Share on other sites More sharing options...
