bpm Posted September 26, 2005 Share Posted September 26, 2005 hey fellas, newbie here with a couple of ?s. i have searched but havent found the info i need. doing an ea81 to ea82t converson in my 87 brumby (brat). wiring is not an issue (aftermarket ecu) and i know it should bolt up to my ea81 4 speed. i need to know can i use the ea81 flywheel and clutch and is there any crossmember modifications needed? also is there a straight fit distributor from any model with a magnetic type pickup? Quote Link to comment Share on other sites More sharing options...
Ross Posted September 27, 2005 Share Posted September 27, 2005 You should be able to use a distributor of a pre 1987 ea82t. Why dont you put a 5 speed in with it? Quote Link to comment Share on other sites More sharing options...
bpm Posted September 27, 2005 Author Share Posted September 27, 2005 cheers Ross. will get an early disy. just put new bearings through my box plus none of the importers have got a box to suit. its my daily driver also so i want do do the swap inside a day at work. have already wired the computer just needed to know about theflywheel etc so i dont get stuck Quote Link to comment Share on other sites More sharing options...
Ross Posted September 27, 2005 Share Posted September 27, 2005 I think there may be an issue with the flywheel - i think the bolt holes are larger on the ea82 fllywheel, so the holes on the ea81 may be too small for the ea82 bolt size. However, you could use the ea82 flywheel, with an ea81 clutch disc, pressure plate and release bearing. Quote Link to comment Share on other sites More sharing options...
bpm Posted September 27, 2005 Author Share Posted September 27, 2005 thanks again, will get the parts you suggested and get stuck into it. Quote Link to comment Share on other sites More sharing options...
Snowman Posted September 27, 2005 Share Posted September 27, 2005 Will the EA82 flywheel mate up with the starter correctly? (I think it should, I'm just trying to eliminate all possibilities of hang-ups.) Quote Link to comment Share on other sites More sharing options...
archemitis Posted September 27, 2005 Share Posted September 27, 2005 note: you have to keep the same pressure plate with the same flywheel. you either have to use the ea82 flywheel, with ea82 pp, and ea81 friction disc. or my favorite, drill out the ea81 flywheel bolt holes either 1 or 2 mms i forget. then you use all the ea81 clutch, flywheel and pressure plate. if you do this, transfer timing marks. i think the ea81 flywheel weighs less now, this is all assuming your ea81 flywheel is an 8 7/8 inch. if its the small one, the ea81 flywheel wont work. you can use any ea82 distributor off of a carb model as well as the early mpfi disty. Quote Link to comment Share on other sites More sharing options...
bpm Posted September 28, 2005 Author Share Posted September 28, 2005 ok, clutch and disy sorted, but now ive heard that it will not fit within the chassis rails without modification. can anyone confirm this? Quote Link to comment Share on other sites More sharing options...
baccaruda Posted September 28, 2005 Share Posted September 28, 2005 it should fit fine. the older brumbys need frame rail surgery, but your generation doesn't. Quote Link to comment Share on other sites More sharing options...
bpm Posted October 13, 2005 Author Share Posted October 13, 2005 Ok, its done, and goes quite well. had to cut a BIG chunk out of the standard crossmember and strengthen it because of the exhaust crossover. frame rails needed a slight massage with a big hammer and engine mount slots in the crossmember needed to be lengthened. drilled out the bolt holes on the standard flywheel and it all bolted together easily. took a total of 5 hrs from driving it into the shop to driving it out for some tuning. thanks all for your help. Quote Link to comment Share on other sites More sharing options...
Snowman Posted October 13, 2005 Share Posted October 13, 2005 That's awesome that it went so quickly. Got pics? Quote Link to comment Share on other sites More sharing options...
