juztin Posted November 16, 2005 Share Posted November 16, 2005 hi all! i just bought a 1987 xt DL, non-turbo, and i've got so many questions.... first, how can i tell if it is 4WD? when i took it to the shop to have the muffler changed, he said it was "all wheel drive", but i want to make sure... also, i've got a small leak somewhere...at first i thought it was coming from the CV boot alone (because it's busted, to be repaired soon), but the same shop that changed my muffler said that it wasn't coming from the CV boot because it was oil, not grease....i've been steadily checking my levels, and it appears that my oil level isn't dropping, but my gear oil level is...however, i've yet to pinpoint the spot the leak is coming from. are there some common spots i could check that this leak would be coming from, or ways to determine if it is in fact gear oil? thanks in advance! Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 16, 2005 Share Posted November 16, 2005 If you have an Orange 4WD button on your shifter, you have 4wd, not awd, i don't believe the XT DL's came with AWD, as far as your leak, do you have an auto or a 5 speed? Quote Link to comment Share on other sites More sharing options...
juztin Posted November 16, 2005 Author Share Posted November 16, 2005 ok, there's no buttons on my shifter, so it's not 4WD... as far as the transmission, it's a five speed. Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted November 16, 2005 Share Posted November 16, 2005 If there is anyway possible you could jack it up on a lift and pressure wash the under side that would be a good start to tell where it's coming from. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 16, 2005 Share Posted November 16, 2005 look under the car - if you have rear axles to the wheels then you have 4WD or AWD. if there's nothing, then you fot FWD. best to clean the underside really good and see where the leak comes from, see what starts getting oily first. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 16, 2005 Share Posted November 16, 2005 for XT or Xt6 specific info www.xt6.net is a good resource as well. for your motor and trans and most things you'll get all you could ask for here though, much larger membership base. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 16, 2005 Share Posted November 16, 2005 If there is anyway possible you could jack it up on a lift and pressure wash the under side that would be a good start to tell where it's coming from. This would be the easiest. Just a helpful hint, leaks almost always start the farthest forward and the highest up. so a leak on the top of the engine can look like a flood from the transmission. Quote Link to comment Share on other sites More sharing options...
