wheels Posted November 20, 2005 Share Posted November 20, 2005 was running fine, i started my 87 hatchback to warm up in the morning it fired right up then a few moments later it made a pop sound and died, i cant get it to start agian. any suggestions? Quote Link to comment Share on other sites More sharing options...
Skip Posted November 20, 2005 Share Posted November 20, 2005 87 Hatchback?? do you mean 3 door coupe? EA82?? if yes ---- timing belt broke is a good bet Pull the dist cap and crank it no rotor spin = no driverside timing belt Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 21, 2005 Share Posted November 21, 2005 what skip says would pertain to you if your car is wedge shaped and has single composite headlights. this body is referred to as a 3-doo(86-89) the hatch back(80-89) is referred to the older bodystyle with 4 individual headlights and looks like a short 2-door wagon check out this link to learn about the different body styles and to let us know which one your car is so we can help you better if yours is the one with timing belts check out the article in the service and repair section http://www.economysuperstar.com/milesfox/subaru/models.htm Quote Link to comment Share on other sites More sharing options...
iteamsubaru Posted December 7, 2005 Share Posted December 7, 2005 I have an EA82 just did the exact same thing to me an hour ago!!!! timing belts? Quote Link to comment Share on other sites More sharing options...
