sanada Posted December 3, 2005 Share Posted December 3, 2005 i just completed an engine overhaul on my 91 Justy. i have adjusted the throttle-sensor and replaced the fuel pump. when i start the car cold, car starts and runs well. but when engine has been warmed up, it is difficult to start the car again unless i cool the car down. can someone tell me whats wrong and how i can solve this problem. thanks Quote Link to comment Share on other sites More sharing options...
nipper Posted December 3, 2005 Share Posted December 3, 2005 what does it do when it wont start? nipper Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted December 3, 2005 Share Posted December 3, 2005 I'd guess the coolant temperature sensor (CTS) is bad. No idea where it's located on a justy though. Would be cheapest to replace from a junkyard; I believe dealers want big $$$ for them. Quote Link to comment Share on other sites More sharing options...
sanada Posted December 5, 2005 Author Share Posted December 5, 2005 what does it do when it wont start? nipper nothing.. i have to sit and wait till the engine cools before i can started up again. Quote Link to comment Share on other sites More sharing options...
Esteban32696 Posted December 5, 2005 Share Posted December 5, 2005 I have seen the coil cause symptoms like that. See if it is getting a good strong spark,at the plug wire while trying to restart it, when hot. Quote Link to comment Share on other sites More sharing options...
sanada Posted December 7, 2005 Author Share Posted December 7, 2005 Update ..... thanks a lot for your info. you point out problem like magic. WHAT A WISE! I put a new CTS in this morning, Justy starting well on any temperature and running well. Thanks again. I'd guess the coolant temperature sensor (CTS) is bad. No idea where it's located on a justy though. Would be cheapest to replace from a junkyard; I believe dealers want big $$$ for them. Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted December 7, 2005 Share Posted December 7, 2005 Update ..... thanks a lot for your info. you point out problem like magic. WHAT A WISE! I put a new CTS in this morning, Justy starting well on any temperature and running well. Thanks again. awesome, glad it was an easy fix. -Dave Quote Link to comment Share on other sites More sharing options...
