cptjas Posted January 11, 2006 Share Posted January 11, 2006 Have an 05 WRX with 18" Tarmacs and Falkens. Lowered using Tein springs and now there is a "pop" when a hard right hand turn is made that sounds like it is coming from behind my drivers side front wheel. It does make the care a bit loose in the curves during the "pop". It always happens in a hard righty. Any suggestions on fixing this? Email JSARMYOFONE@AOL.COM Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 12, 2006 Share Posted January 12, 2006 Did you install them, or did someone else install them? There is a cone shape washer that goes between the upper spring seat and mount. If that is left off or installed incorrectly, the spring seat will not pivot freely on the bearing in the mount. That's where I'd start. Quote Link to comment Share on other sites More sharing options...
blitz Posted January 12, 2006 Share Posted January 12, 2006 I get the same pop in the same spot on my '02 OBS when turning the wheel right, except that it happens when straightening out after having made a sharp left turn. I have no idea what's causing it. Quote Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted January 25, 2006 Share Posted January 25, 2006 3 posibiltys mentioned to me once about that. 1 steering rack tie-down bushings bad ( i'm sure there is a better name for it) 2 rubbing of tire against wheel well under heavy steering 3 change of CV joint pitch, pressure or position due to suspesion upgrade I'm sure there are like 20 other posibilties:grin: Quote Link to comment Share on other sites More sharing options...
cookie Posted January 25, 2006 Share Posted January 25, 2006 I have heard of a misaligned spring catching abd then releaseing. Quote Link to comment Share on other sites More sharing options...
Andyjo Posted January 25, 2006 Share Posted January 25, 2006 swaybaris pissed off, and unseated spring, i forgot to put in the rubber thingunder the spring... makes that noise Quote Link to comment Share on other sites More sharing options...
tomeverett13 Posted February 8, 2009 Share Posted February 8, 2009 ball joint my just came off and i lost my front tire Quote Link to comment Share on other sites More sharing options...
EVOthis Posted February 8, 2009 Share Posted February 8, 2009 was the "pop" there before the springs where installed?...is the spring seated properly on the perch and upper strut mount? Quote Link to comment Share on other sites More sharing options...
