banny Posted February 6, 2006 Share Posted February 6, 2006 I have a 2005 Subaru Legacy 2.5i, 5-speed manual transmission. When I use cruise control, the cruise control will shut off sometimes. When I say "it shuts off", I mean it no longer keeps the speed I set it at and gas pedal is no longer depressed, but the "cruise" light is still on. So it's kind of like when you're in Cruise Control and you tap the brake, even though I didn't. At first, I thought it was happening only when the engine exceeded 3k RPM but, but it seems it happens at slower speeds as well. Anyone else experience this problem? Thanks. Quote Link to comment Share on other sites More sharing options...
subeman90 Posted February 6, 2006 Share Posted February 6, 2006 the first thing I would check if I was to work on it would be the brake (and also in this case clutch) switch. Maybe the tolerance is set too close and a bump in the road is enough to trip the switch. See if it happens when you hit bumps. Been down this road once in an 85 blazer years ago. Otherwise...you got warranty...let them figure it out. Matt Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted February 6, 2006 Share Posted February 6, 2006 try searching at www.legacygt.com I know they have a similar problem listed over there. Quote Link to comment Share on other sites More sharing options...
Setright Posted February 7, 2006 Share Posted February 7, 2006 Pulling the CC stalk toward you will cancel the setting, Maybe you are knocking it with your knee?? My 2006 Forester lights up the "Cruise" in the dash but also has a "Set" light that comes on when the computer has taken charge. Quote Link to comment Share on other sites More sharing options...
nipper Posted February 7, 2006 Share Posted February 7, 2006 I have a 2005 Subaru Legacy 2.5i, 5-speed manual transmission. When I use cruise control, the cruise control will shut off sometimes. When I say "it shuts off", I mean it no longer keeps the speed I set it at and gas pedal is no longer depressed, but the "cruise" light is still on. So it's kind of like when you're in Cruise Control and you tap the brake, even though I didn't.At first, I thought it was happening only when the engine exceeded 3k RPM but, but it seems it happens at slower speeds as well. Anyone else experience this problem? Thanks. is there any pattern to it shutting off? Under any specific conditions? nipper Quote Link to comment Share on other sites More sharing options...
Legacy04 Posted February 8, 2006 Share Posted February 8, 2006 I just noticed the same thing on my 04 2.5. Seems to shut off when going up a very slight incline. Light stays lit, gas stops though. I think it's under warranty until 36K. Quote Link to comment Share on other sites More sharing options...
Legacy04 Posted February 8, 2006 Share Posted February 8, 2006 Just spoke with the stealership & there was a recall on the unit. Quote Link to comment Share on other sites More sharing options...
Juan Posted February 9, 2006 Share Posted February 9, 2006 When I say "it shuts off", I mean it no longer keeps the speed I set it at and gas pedal is no longer depressed, QUOTE] How can you tell if the gas pedal is depressed? Juan Quote Link to comment Share on other sites More sharing options...
rcoaster Posted February 9, 2006 Share Posted February 9, 2006 When I say "it shuts off", I mean it no longer keeps the speed I set it at and gas pedal is no longer depressed, How can you tell if the gas pedal is depressed? Juan Yeah, I was wondering too because the 2005's are "fly by wire" systems. Your gas pedal doesn't have the throttle cable but a potentiometer attached to it which in turn, controls a servomotor on the throttle plate. You don't have the feedback with cable actuated systems. My 2004's crusie control is a fly by wire system, but still uses the actuator cables, so I do get the feedback. Quote Link to comment Share on other sites More sharing options...
Legacy04 Posted February 9, 2006 Share Posted February 9, 2006 Dropped off car last eve, and stealer called me this AM saying there was NO recall, but it will be fixed under warranty. Quote Link to comment Share on other sites More sharing options...
Zephyr Posted February 9, 2006 Share Posted February 9, 2006 Dropped off car last eve, and stealer called me this AM saying there was NO recall, but it will be fixed under warranty. software update? Quote Link to comment Share on other sites More sharing options...
Legacy04 Posted March 10, 2006 Share Posted March 10, 2006 New computer so they say. Quote Link to comment Share on other sites More sharing options...
