rideordice Posted February 22, 2006 Share Posted February 22, 2006 i have a 89 turbo gl wagon, i bought it with it supposedly having bad head gaskets. when i bought it to start it i had to put my foot to the floor and crank it for like 30sec+ to get it to start. i attributed that to the blown head gasket. now i have 2 different heads on it both resurfaced both with grinded valve seats and faces and new seals, new head gaskets and a differnt block out of another turbo subaru cause i pulled the threads out of my block while torqueing the heads down. when i start the car it idles pretty ruff, enough so when i put a timing light on it its jumping all over the place. and its a kinda high. when i shut down the engine and go start it again it doesnt want to start unless my foot is to the ground and and i crank if for almost ten seconds. any ideas to why my car is acting this way would be much appreciated. thanks. Quote Link to comment Share on other sites More sharing options...
torxxx Posted February 22, 2006 Share Posted February 22, 2006 crank angle sensor is buggin out? sounds like a major vacumn leak to me. Quote Link to comment Share on other sites More sharing options...
naru Posted February 22, 2006 Share Posted February 22, 2006 i have a 89 turbo gl wagon, i bought it with it supposedly having bad head gaskets. when i bought it to start it i had to put my foot to the floor and crank it for like 30sec+ to get it to start. i attributed that to the blown head gasket. now i have 2 different heads on it both resurfaced both with grinded valve seats and faces and new seals, new head gaskets and a differnt block out of another turbo subaru cause i pulled the threads out of my block while torqueing the heads down. when i start the car it idles pretty ruff, enough so when i put a timing light on it its jumping all over the place. and its a kinda high. when i shut down the engine and go start it again it doesnt want to start unless my foot is to the ground and and i crank if for almost ten seconds. any ideas to why my car is acting this way would be much appreciated. thanks. You are flooded.Most likely leaky injectors.Check the CTS too-try unplugging it. Quote Link to comment Share on other sites More sharing options...
rideordice Posted February 22, 2006 Author Share Posted February 22, 2006 i thought it sounded like it was flooding due to me havin to put it to the floor, i have another set of injectors from another turbo ill put in and see what it does. i made pretty sure to have all the vacum lines right cause the guy who had it before me had the waste gate vacum lines all bass ackwards so i went to the junk yard and made a diagram from a running turboso to get all the solonoids and lines in the right places, ill double check though. would try and unplugg the cts but i dont know what that is. can also through another crank angle sensor it and see if it changes. thanks for the help. Quote Link to comment Share on other sites More sharing options...
naru Posted February 22, 2006 Share Posted February 22, 2006 i thought it sounded like it was flooding due to me havin to put it to the floor, i have another set of injectors from another turbo ill put in and see what it does. i made pretty sure to have all the vacum lines right cause the guy who had it before me had the waste gate vacum lines all bass ackwards so i went to the junk yard and made a diagram from a running turboso to get all the solonoids and lines in the right places, ill double check though. would try and unplugg the cts but i dont know what that is. can also through another crank angle sensor it and see if it changes. thanks for the help. cts is the coolant temp sender. I think it is on the rear of the manifold on your engine. Quote Link to comment Share on other sites More sharing options...
