Vacuum Diagram - 96 2.5 Outback
Doing a HG job on a 96 2.5/auto Outback and I forgot to label a couple of the vacuum lines on the passenger side when I pulled the intake off. I did a search and found this thread (http://www.ultimatesubaru.org/forum/showthread.php?t=51974&highlight=vacuum+diagram) which was addressing an early 90's motor, would it apply to my 96?
There are 2 lines coming off the fender (pressure sensor & switching solenoid valve?), one with what looks like a check valve. There is a nipple on the intake, a brown nipple below the intake (purge control solenoid valve?) witha seconf line that has a tee, and a line coming off the fuel rail (pressure regulator?). Anybody have a good vacuum diagram that will clarify these lines?
A picture says a thousand words. I just went outside to take a picture under the hood of my 97 Outback with the 2.5. It's dark here so the shot may not be exactly composed as I wanted, but I think it shows clearly enough where the vacuum lines go. As you can see, I still have tape on the vacuum lines marking where they go as I had the engine out last year for a HG.
The line leading out of what looks like a flow control, goes to a Tee and then to the intake manifold.
I will try to answer any other questions you may have after you look at the picture.
I am having trouble sending/attaching a picture to this post. If you would
like to see it, send me your email address and I'll forward it to you using my normal email
Regards;
Ken
