Caboobaroo Posted June 15, 2006 Share Posted June 15, 2006 So I have this mastercylinder I can get off of a '96 Impreza 2.2 manual awd car. I was wondering if it can be fitted to an EA82 brake booster or can I use the brake booster from the Impreza onto my RX? I have the following brake mods and such: Impreza 2 piston calipers with EBC green pads XT6 rear rotors with calipers plus I'm going to be getting some SS brake lines as well. Also gonna get some crossdrilled rotors for it. Quote Link to comment Share on other sites More sharing options...
suberdave Posted June 15, 2006 Share Posted June 15, 2006 i was wondering the same thing. i have almost the same setup. the only reason i haven't is cuz the EA master cylinder seems to work just fine. -=Suberdave=- http://www.suberdave.com Quote Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted June 15, 2006 Share Posted June 15, 2006 I run a Legacy 15/16" MC in my 'ea82' bolted right up only thing I had to do was plug one of the brake line holes as they only had the part for an automatic in stock at the time.. one trimmed 10mm w 1mm pitch and one copper banjo washer later and I was done the rest bolted in with no other modifications.. I'm using stock brake booster.. Oh it's a 90-93 legacy part BTW, Legacy MC can be had up to 1 1/16" in bore but you only get that bore with ABS and how the lines hook up seems to be different..I seem to recall that 1" was the largest bore to be had non ABS..I woulda gotten that if it had been in stock.. HTH, Kaz Quote Link to comment Share on other sites More sharing options...
